Group Buy, New R33 Front bar.
  • Replies 54
I am very interested, but would like to see a picture of it on a car to be sure.
Dont take this the wrong way, but what is the quality of the bar like? My car is beeing painted by one of the top (most fussy) painters in SA, and if it dose not sit in correctly, or isnt straight he wont touch it. (dont want to waste your time and money shipping it back to you)
I am going to pair it up with an impule bodykit, but I am unable to get a front bar at the moment (nor for the forseeable future), hence the need to look at alternatives.
PS what would it cost to ship it to Adelaide? (in the next week (2 weeks at the most))
Guest MFX_R33
My car is in pieces at the moment (and has been for 8months) and wedged in a corner, so you wouldn't see much.
As for the aero dynamics, the bar is designed to give a good amount of front downforce, and is also designed to go with the carbon fibre cannards we are currently finishing off.
The bar is also designed around a 600x300 intercooler, so you can receive maximum flow.
Jeff.
i just wanted to know where u tested its aerodynamics. as to do this properly you would need to put it on a car then put it thru a wind tunnel you would also have to put the original car in a wind tunnel to see the differences in downfoce. Only monash clayton has these facilities in australia. the wind tunnel their goes to 200 km/hr. and its very expensive to hire...
dont want to start a nerd-fight in someone elses thread - but you sir, are a goon!
Guest MFX_R33
No we have not tested the bar for exact aero dynamic properties. As I said we have "designed" it to give a greater amount of front down force, using the wing shapes on either side of the bar, and as I mentioned before, with the optional carbon fibre canards.
If someone on here wants to know the drag coefficeint of the car before and after the kit, they would be hard pressed to find it for any kit. This factor will also change for most cars at any rate, as it depends on may other factors as well, including ride height, and the other aero parts they have fitted to their car.
This said, most people buy body kits for purely cosmetic reasons. We are offering an alternative to the limited range of R33 kits available in Australia. There are very few companies in Australia producing NEW stuff. If you like it that's good, if you don't that's fine too. We are just offering you guy's another choice.
Jeff.
    • Great interview on damper settings and coil selection by HPA https://www.facebook.com/HPAcademy/videos/30284693841175196/?fs=e&s=TIeQ9V&fs=e
    • Yeah, it was a pretty deep dig.
    • The values for HID colour are also defined ~ see https://www.legislation.gov.au/F2006L02732/latest/text  ~ goto section 3.9 onwards ....
    • So, if the headlights' cutoff behaviour (angles, heights, etc) are not as per 6.2.6.1.1 without automatic levelling, then you have to have to have automatic** levelling. Also, if the headlight does not have the required markings, then neither automatic nor manual adjusters are going to be acceptable. That's because the base headlight itself does not meet the minimum requirement (which is the marking). ** with the option of manual levelling, if the headlight otherwise meets the same requirements as for the automatic case AND can be set to the "base" alignment at the headlight itself. So that's an additional requirement for the manual case. So, provided that the marking is on the headlight and there is a local manual adjustment back to "base" on the headlight, then yes, you could argue that they are code compliant. But if you are missing any single one of these things, then they are not. And unlike certain other standards that I work with, there does not seem to be scope to prepare a "fitness for purpose" report. Well, I guess there actually is. You might engage an automotive engineer to write a report stating that the lights meet the performance requirements of the standard even if they are missing, for example, the markings.
    • Vertical orientation   6.2.6.1.1. The initial downward inclination of the cut off of the dipped-beam to be set in the unladen vehicle state with one person in the driver's seat shall be specified within an accuracy of 0.1 per cent by the manufacturer and indicated in a clearly legible and indelible manner on each vehicle close to either headlamp or the manufacturer's plate by the symbol shown in Annex 7.   The value of this indicated downward inclination shall be defined in accordance with paragraph 6.2.6.1.2.   6.2.6.1.2. Depending on the mounting height in metres (h) of the lower edge of the apparent surface in the direction of the reference axis of the dipped beam headlamp, measured on the unladen vehicles, the vertical inclination of the cut off of the dipped- beam shall, under all the static conditions of Annex 5, remain between the following limits and the initial aiming shall have the following values:   h < 0.8   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   0.8 < h < 1.0   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   Or, at the discretion of the manufacturer,   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The application for the vehicle type approval shall, in this case, contain information as to which of the two alternatives is to be used.   h > 1.0   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The above limits and the initial aiming values are summarized in the diagram below.   For category N3G (off-road) vehicles where the headlamps exceed a height of 1,200 mm, the limits for the vertical inclination of the cut-off shall be between: -1.5 per cent and -3.5 per cent.   The initial aim shall be set between: -2 per cent and -2.5 per cent.
