Hi fellow Stagea owners,
Just after the size of the Series 2 headlight and highbeam light globes (H1,H3 ect ect...?) Factory xenons seem to be have deteriorated in brightness and looking at a new more powerfull xenon replacement kit.
Best regards Chris.
https://www.sau.com.au/forums/topic/392635-stagea-headlight-globe-sizes/
S2 Xenon are D2R lamps @ 35w
the High Beam are H3 i think, is stamped on the top plastic on the high beam
i hope this helps.
Also the Xenons may be dim because the lamps are dying. try getting new lamps and you will see a marked improvement,.
the high beams are a strange type, pull them out and you will see
the plug goes into plastic which does a 90° turn into the bulb
the xenon bulbs don't take a H bulb, being xenon and all
No worries thanks for the information you have provided Michael. For arguments sake though why wouldn't you go HID high beams?
And how did you go about your 4000k high beams were they a direct plug and play unit or did they have to be modified to fit, Where did you purchase them from if you don't mind me asking?
plug nd play. autobarn blue vision. but any HB3 will work. just a matter of how white u want the light as too how high of K rating u get. if u want to see mine car catch up somewhere in hills on the weekend at night or something.
  • 6 years later...
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
