Welcome to the ever growing club rep ;)
"OEM RB25DET piston ringlands - built to be busted"
Since having mine built with strong internals and running big boost I've found a large interest in wide competition style rear rubber!
  • Replies 98
CMS Drifter , you got the easy job! I've gotta PAY for the whole thing :rant:
About half way now , engine out (thanx CMS) & fully pulled down.All gaskets , bearings and belts here , pistons & rod bolts arrive Monday . The block gets bored and decked this week before going to Perth to be "O"ringed , and while I'm there , drop off the stall converter & pick up my new rods:D
Getting Keen Now!
Take one fully functional R33 making 280rwhp constantly,
add One Hi-Flowed steel wheeled turbo,
spool boost briskly to exactly 15psi (note: you should be able to smell the rich aroma of "Smoked" 265's at this stage)
You will notice a flury of detonation as the boost spools up ,
Now this is the important part..... carefully remove your Brain and place it heavilly
on your right foot ,
add to this the classic Aussie "She'll be right" &
Ta Da.... You have successfully Shot the dipstick ( oil Not driver) out of the sump due to the massive crankcase presssure caused by broken ring lands!!!!!
If you've done this right , the cab will fill with clouds of choking smoke with just a hint of anal discharge :fart:
See the illistrations below......Happy RB25 Cooking :)
Crap you have just described my driving method.:rant:
Troy Rep.
:Bang:
Hmm nice. The GTR rods are heavier than RB25 so even though I lightened the flywheel I noticed there was only a slight improvement response wise.
Gav , the RB26 rods will do me :rant: They can more than handle the 250rwkw I'm chasing.& are cost effective compared to aftermarket items.
B-man , I only killed 1 piston outright.....couple of others had cracked ring lands...& no.5 dropped the spark plug!!(still haven't found that!)
Morgs ,is there a place on the web that your not on? :cheers:
Pistons & rod bolts arrived today! :)
what would the ARP bolts come in at?
When I put mine together I had one that wouldn't accept the torque required and it started to neck, so I found most had been seriously stretched when I measured them, about 3-4 mm.
New RB26 bolts from Nissan cost about $180 from memory and had to come from 3 different places to make the set. Even so they pack then in fives...morons...and wanted me to pay overnight freight for the last 2 AND they sent me lawnmower bolts the first time.
At least they sent the cutest parts runner around with the last delivery :D. But she was blonde and wanted me to pay for them again...AAARRRGHHH...save us from Nissan Aust.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
