Hi all its time to part with my gtr but all for a good cause to buy a house so here it goes.
$25000 Neg
The car is a 1989 R32 gtr skyline with a fresh built that Paul from Red R racing put together here are the details.
R34 gtr crank
CP 40 thou pistons with modified eagle rods
Hks oil pump and trust sump with modified oil return and restrictor fitted
Tomei Pon cam type b's and valve springs and retainers
tomei adjustable cam gears
spit fire coil packs
2860-5 turbos with r34 gtr stainless dumps and veil side front pipe and a varex muffler
The car produced 430 hp at the wheels with a Guilt toy tune. There is plenty more left in it with a less restrictive exhaust.
The car is also fitted with 18*9 +15 lenso DR1 rims.
JJR adjustable camber arms front and rear with bilstein coil overs
Top end sterio kenwood head unit, JL splits and JL rears $2000 worth alone come with sub and amp just havent gotten to fit it yet
Viper alarm is installed
there is probably other things i have forgotten to mention but feel free to hit me up
My number is 0434108477 feel free to ring me or txt me.
thanks scottie
https://www.sau.com.au/forums/topic/392657-built-r32-gtr/
  • Replies 45
List what ecu injectors fuel pump/ system. There is more mods to this car than what u have stated. Having a red r racing engine u know it one of the best.
Nice car and its well worth the low 20s
https://www.sau.com.au/forums/topic/392657-built-r32-gtr/#findComment-6247001
Sorry like i said alot to list it has and cheers i think i have priced it fairly like i said i am negotiable oh and the motor is 8 000km old
HKS 1000cc injectors bosch 040 fuel pump and a power fc with hand controller
https://www.sau.com.au/forums/topic/392657-built-r32-gtr/#findComment-6247010
Long engine alone is well worth half the asking price. Plus all the bolt ons someone wil get a good car by the look of it.
I have 2 gtrs if I didn't already or had a spare lump of cash would buy this just to save on the engine hastles of an unbuilt engine or unreliable engine built by some shop that don't know the rb engines.
Paul is one of if not the best rb engine builder in the country in my opinion.
Good luck with your sale ill spread the word of a quality gtr for sale
https://www.sau.com.au/forums/topic/392657-built-r32-gtr/#findComment-6247270
hi it is running 21 psi atm and the turbos where brand new when the motor was built so they have 8000km on them they also have the oil restrictor fitted in the banjo lines to. goz1llaaa34 yes there is alittle bit of rust i will post some photos for you tonight and interior pics will be put up as well thanks for the interest guys
https://www.sau.com.au/forums/topic/392657-built-r32-gtr/#findComment-6247366
Thanks mate, does the air con work ?
Hey sorry mate air con does work but needs to be re gassed which i can organise it to be done and here is acouple of interior pics
https://www.sau.com.au/forums/topic/392657-built-r32-gtr/#findComment-6248436
Could you please tell me where exactly are the rust spots? So that I will have a clue. PM me if you like...
heya sorry mate i completely forgot about that here are a couple of photosof the rust. the rest of the body is straightas with only like 2 noticeable dints. There no rust in the sills or under body at all. I was quoted $3000 for the rust repairs with all the windows removed rust plated and the roof and rear quarters repainted. Other than that and the front seats being average the car is in very good condition and i forgot to add it has a Jim berry single plate custom clutch also which i would have to say is the best clutch i have driven.
https://www.sau.com.au/forums/topic/392657-built-r32-gtr/#findComment-6253182
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
