Hi All,
After much hunting around for a Media/stereo solution for my M35 I have some helpful info for anyone trying to think of a setup.
1. This system started as a stock Jap system. First I wanted to have the TV work in Australia. So I brought a car TV tuner on ebay and had Andy install it.
He did a great job but the Tuner works fine all through Sydney, but the moment you drive to Newcastle... Bang! to tuner will never again get signal.
If you live in newcastle a TV tuner is out of the question ( I wish I new this before I spend $350 getting a tuner installed)
2. Now I have ripped out the tuner and installed a WDTV live media player with WiFi.
I installed a Infrared Extender from Jaycar that runs on 12VDC, this allow me to use the remote in the front and have the WDTV in the boot compartment.
Benefits:
1. Will play .MKV files
2. The WDTV runs on 12VDC
3. you can tether your phones internet and watch YouTube and other smart TV programs.
4. download DLNA apps on your phone and play movies off your phone directly to you TV screen wirelessly including music!
5. Load up a 500g hard disk drive full of movies and music and plug it in!
Screw the TV (in Newcastle) and get a WDTV.....
Hope this helps people pick a solution for there media setup.
https://www.sau.com.au/forums/topic/392673-m35-media-solution/
Hi All,
Hi James
Did you rescan for TV channels in your local area?
With any TV tuner you have to retune when you move more that about 60-100km from you home base.
I would be surprised if you were unable to get reception in Newcastle. If you can get reception in your house with out a 40ft aerial on the top of your house you will get reception in your car.
Cheers
Andy
you can check out my 7" android tablet install in the other thread ;)
Yeah seen that - I don't want it mounted up front...I want 2 tabs mounted behind each front headrest for the kids...
I do have a cradle up front that can hold a tab if I really want to though...
Hi James
Cheers
Andy
Hi Andy,
Yeah I tuned it numerous times in many parts of Newcastle, I can get NBN (channel 9) in about 5 suburbs and always breaking up and not worth watching. Iv read about this on other forums, apart from main Australian cities, (sydney, melbourne, brisbane, gold coast etc.) TV reception in Australia is way below par with the rest of the world.
Just got back from a weekend in Canberra. Only Sydney and Canberra was the only parts I got reception. Only about 1hr of a 4.5hr drive. Worth ripping out id say.
Hi Andy,
why don't you just put a Ipod/Phone dock into the spare RCA for the time being(or until Digital gets to the coast) and watch movies/play music?
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
