Hello all!
New to the SAU forums but I may have lurked here for quite some time..
So, I had some questions I was hoping some Victorians could help me with.
- Does anyone have any information regarding tall people and R34's? I'm 6'9 and have been searching around for some information regarding room issues but nothing really came up with a answer.
- If no to the first question does anyone know of a car yard that has any 5 Speed R34's in stock? I'd much rather go to a car yard and see whether or not I can make myself fit instead of finding someone doing a private sale. I'd just rather not waste someones time like that only to find out my "bigfootism" will stop me from pursueing the sale.
Thanks in advance!
https://www.sau.com.au/forums/topic/392705-looking-for-some-advice/
33 would probably be a far better option, it's a much larger car than all the other RB based Skylines. 4 doors all have higher roofs so unless you're set on a coupe they will probably be better for your height.
Thanks for the information fellas!
I kinda had my worries that I would struggle with room so I was planning to budget in buying a aftermarket seat with some side mount rails.. BUT the main problem would be getting it home in the first place to even mount them up. Even then I'm not 100% sure that would work out in terms of being comfortable.
Also if anyone else has suggestions on cars I may yet have thought of would be great. (p.s. I don't fit comfortably in almost anything =P )
If you want, you are more welcome to try my R34, it's got super low rails with a Bride Low Max lol.
You might possibly fit height wise, but you probably wont fit into the seat haha, I'm 60kg and it hugs me just fine...
Thanks for the offer Charles I may take you up on that... Found a car to look at on Sunday after work so fingers crossed I can figure something out with the stock seat :)
p.s. your 34 looks awesome!
Cheers man :)
Yeah, no worries, just lemme know.
Charles do you use a cushion or something to see over the dash if you have low-rails?
Of course not, I just squat on my seat......
LOL nah, I can just somehow see over my dash just fine....
Part 2.
- What major items should I be looking at in a R34 for signs of abuse?
- Does anyone have any suggestions for a comfortable aftermarket seat? Ideally ADR approved. Have been looking at Sparco / Velo so far.
    • Late to this party but here is your go to shop in perth - https://www.facebook.com/gsautoworksau GTSBOY is on the money cost wise, drive in and out will cost you 15-30k or more.    Some items that will save you money  - plug in link ecu g4x is much cheaper than haltech.   -Pulsar turbo, seem to be "OK" now, never used one myself You really don't have to build the motor, E85, headgasket, studs and a good RB26 will live for ever.    Swapping over the twins won't save much as you still need ecu, tune, fuel system etc.
    • Welcome back to the scene! Godzilla Motorsports were well regarded back in the day.  My GT-R had work done there prior to my ownership.   SRS (Street Race Solutions) in Toowoomba worth a look.  They've built some pretty wild Skylines. Their YouTube channel is comedic to watch!  I'm sure they're all on the glass BBQ but they get shit done! 🤣
    • Hard to say what the extra connector is, it looks a bit like a coax type connector, so possibly a separate radio/GPS antenna, or even another camera input?  The V37 series (including the Q50), did go through a model refresh in 2020, since Australia didn't get any Q50s newer than 2019, we didn't get any of the refreshed models, so there could also be other unexpected problems to overcome to swap an older Q50 head unit into a new model V37. There probably aren't too many people around that have made these sorts of changes to a Q50/V37, so you might end up being the first if you do decide to go ahead. ACP is Apple Car Play and AA is Android Auto, they are roughly the same thing for the 2 major phone operating systems (Apple's iOS and Android), it allows you to connect your phone and access a number of your phone applications on your car system.  With Nav apps included, so you could use google maps/Waze or whatever your favourite navigation app is, instead of using the built in navi system.  I think this would be a better solution if it is only Navigation that you are looking as swapping the head unit for. GPS signals are the same around the globe as the GPS satellites continuously circle the globe, but it is the head unit that doesn't allow you to load Australian maps, or at least no-one had made an Australian map that will load up on the JDM head unit. Regarding the TV standards, I assume you are referring to the AV inputs?  I haven't ever tried to use them, Japan used a slightly modified version of the US NTSC system, and Australia uses PAL for composite video, that said, I wouldn't be surprised if a video input could work with either system.  That is mostly irrelevant here though, unless you plan to use those inputs for something?
    • If you've got bucket loads of $. Go single. If not, just upgrade the twins, Garrett -9's or whatever the current equivalent is for a healthy 350awkw and leave it at that. Will probably still cost you 10k to do in this day and age.
    • When you looking to buy injectors?? I could possibly sell you my 1d1700s for decent price. Done little work I just need bigger again 😫
