Hello!
I have recently purchased an R34 Skyline. However, in the car, there is a Xanavi Dvd/Player built into the dash which is in Japanese. i cannot understand Japanese. Also, there are buttons beneath the screen which are in japanese. Please help!
The photo is below.
Kind Regards!
https://www.sau.com.au/forums/topic/392771-need-help-asap/
Bahaha - gold
One of the Stez guru's will see this and maybe know how to change language to english.
Stating the obvious = Should be a menu item in the settings/set-up (in japanese but the word "english" is the same/similar in every language)
RTFM
https://www.sau.com.au/forums/topic/392771-need-help-asap/#findComment-6249084
Use search this topic is covered extensively already
I ditched mine for aftermarket the factory stuff sucks ass
You cant change it to english with a button push and the rest wont work in australia anyhow You can reuse the screen but they fail a lot
You will most likely want to update your dash as well its the old ugly version with ac down low , thats covered already as well
Best of luck search is your friend
https://www.sau.com.au/forums/topic/392771-need-help-asap/#findComment-6249176
