does anyone know of any MFD's that show water temp, oil temp, oil pressure, boost. or any others that work with the Stagea? other then a GTR one? will be good if it shows gauges. or bar graphs. or if there is anything else that will work that is not too expensive.
https://www.sau.com.au/forums/topic/392773-mfd/
going with a nistune ecu now. so will need to work along side that. do u know how hard it is to wire up? or is it consult cable like others?
Informeter plugs into the OBD plug. I'm not sure exactly what it will read on a C34, I've only used mine on an M35.
https://www.sau.com.au/forums/topic/392773-mfd/#findComment-6248441
Engine temp, injector duty cycle, throttle opening, AFM voltage, ambient temp, RPM, Speed, O2, and a bunch more. With additional sensors you can do oil temp, oil pressure, boost pressure etc.
Link;
http://www.greddy.com/products/electronics/informeter/
https://www.sau.com.au/forums/topic/392773-mfd/#findComment-6248577
HKS CAMP 2. straight OBD port and does video onto a screen (I'm assuming that is your question.)
Just did a google on this, and saw that it needed a Nissan Consult cable for our cars... Now is that to connect our nearly OBD II conection straight into the CAMP2, or does it convert it to an OBD II format that the CAMP 2 normal connector can read?
Now, just say it did convert it to ODB II, does that mean it would work with the Garmin Bluetooth dongle thing....
Got to ask... :thumbsup:
https://www.sau.com.au/forums/topic/392773-mfd/#findComment-6248768
the M35 might have the OBD connection already. but the C34 i know need the consult cable to enable it to plug into the OBD connector that comes with the camp 2 nd most other diagnostic tools. as the consult plug is not the same. OBD is 16 pin. not sure about the early nissan ones. haven't counted
https://www.sau.com.au/forums/topic/392773-mfd/#findComment-6248774
I'm pretty sure Jetwreck tried one of those in his M35 and it didn't work. Maybe PM him to check?
https://www.sau.com.au/forums/topic/392773-mfd/#findComment-6248780
Yes, the HKS cable plugs straight into the OBD2 port and either the CAMP2 or the Fcon iS. From there it is a video signal out to a screen.
The connection on the HKS equipment is like a modified RJ11 (home phone).
https://www.sau.com.au/forums/topic/392773-mfd/#findComment-6249241
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
