Gday Everyone
I have a set of Used but in good condition King Springs to lower an R33, I bought them because they are not the super low ones that will attract the cops attention, but low enough to make the car look good. As it turns out my valve stem seals have gone so thats my priority now so I need the money to fix that.
I paid $250 for them a few months ago I am chasing $200 for the set.
I will not separate them, i am only selling them as a complete set.
Also dont know if they will fit any other Skyline
Decent offers welcome but any stupid offers will be replied with a stupid answer from me :woot:
Located on the north side near Kallangur
Cheers
Edited by nthside_skyline
https://www.sau.com.au/forums/topic/392775-r33-lowered-king-springs/
  • 3 weeks later...
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
    • lol no cats running str pipes … might put the high flow back on but I suspect it might effect my ignition timing a bit.
    • That looks a bit like yellowing to me. If the rear bar was looking like that from rich idle, I'd ask the question, do you have a catalytic converter fitted, and fully working?
    • Oh yeah gets really bad down here. I’ll have to upgrade the heater and wind screen wipers as well for optimal performance.
