I have new spool rods going in my beast, and as they don't have a forward mark on them i know you have to make the tongue side go to the torque up stroke side but for the life of me i can't remember which side the bearing grove should be on??? drivers or passengers side unsure.gifwacko.gif
https://www.sau.com.au/forums/topic/392790-rb30-conrods/
Happy to be corrected, but if they dont have markings, then they can ge either way. Im certain the tongues are there to assist assembly, crush holds the bearing
Unless they have piston squirtes on the side of the rod
Edited by Adriano
https://www.sau.com.au/forums/topic/392790-rb30-conrods/#findComment-6251459
thanks guys found out the groves go to the drivers side of the engine, appears all rb engines the same, went to a mate wreckers and we pulled a few down that were fked just to check, secondly with the r32 balancer albeit that everything is balanced now what is the safest power lvl i should push the thing to keeping in mind the revs aswell???
https://www.sau.com.au/forums/topic/392790-rb30-conrods/#findComment-6252247
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
