When i try to start the GTR it turns over fine, but coughs to life, and then runs rough and rpm keeps falling until it stalls - which takes about 10 seconds. Throttle doesn't help to raise the revs. What should i check first? I was thinking maybe fuel pump, but its only about 3 years old (sard) so I hope it hasn't died already.
Any ideas?
https://www.sau.com.au/forums/topic/392843-starting-issue/
Update: no sensor warnings via consult
The car was running fine before I parked it, then dead when i came to start it again, so I think spark plugs are unlikely. I'll try to find a vac leak. Needle in a haystack..... cant use the aerostart trick because it doesnt run long enough.
https://www.sau.com.au/forums/topic/392843-starting-issue/#findComment-6249575
Spark plugs unlikely? Sounds EXACTLY like my car after spark plugs were fitted in about a week earlier. Fresh plugs went in. Drove home from work at night. Parked the car. Next day tried to start it up the car coughed and spluttered, started and died then would never fire up. New plugs, started up just fine. Plugs got fouled.
If you've failed to start the car a couple times, every time after that you are wetting your plugs and pretty much f**king them up. Try new plugs, if it doesn't fire up, then try the fuel pump test. Remove the hose from the fuel pump to the rail, put it into a bucket and check its flow for a couple of seconds. If its moving fuel, and you say throttle doesn't help it start, I'm going to say spark related.
I don't know how you would develop a vacuum leak after parking the car but if you did have one, the car will start and just idle rough with alot of black smoke. Ive had minor and major leaks and each time the car does start, its just rough as ass.
https://www.sau.com.au/forums/topic/392843-starting-issue/#findComment-6249664
Mate you didn't put petrol in it just prior to the problem? I had a similar thing about 4yrs ago n it ended up that the fuel i put in the night before from a servo that "apparently" didn't sell much v'power (shell servo obviously) let their under ground tanks run so low i got so much rust with my v'power i needed to replace all injectors, fuel filter, fuel pump, remove the Farking tank to flush it, only reason i didnt burn the servo to the ground is the owner paid me $1950 for repairs...he insisted i provided legit tax invoice and information of the w'shop that did the repairs so he could call and verify. Which was easy coz i had a workshop :whistling: hope yours aint same issue hey... I'd suggest you pull plugs out just to determine if its getting fuel, and if theyre fouled up you more than likely have a vacuum leak sumwere thats causing it to have the excess fuel pressure. Does billow black smoke or smell fuely when it does inda run?
https://www.sau.com.au/forums/topic/392843-starting-issue/#findComment-6249688
Well i had put in a tank of United 100 as my car seemed to like their 98 a bit more than other 98s, and the station i went to didnt sell the 98 anymore. I haven't smelt fuel. I guess its worth checking how the plugs look as that's pretty easy and will let me know if they're wet with fuel or not. They're iridiums so should be more resistant to fouling than coppers.
The service manual points to fuel pump, so i'll see if supercrap have a pressure tester and get a new filter while i'm at it.
Thanks guys - keep the ideas coming.
https://www.sau.com.au/forums/topic/392843-starting-issue/#findComment-6249771
Check if your plugs are getting wet, are the injectors pulsing? Remove a spark plug and touch it to the head, can you see a spark arc? Need to know if you are lacking fuel or spark. My money is still on plugs. fould plugs.won't look any different to working plugs. You were getting coughing and now it's just turning over without any coughing. Would indicate either no fuel flow at all (unlikely), or no spark.
https://www.sau.com.au/forums/topic/392843-starting-issue/#findComment-6251240
    • Good timing mate, welcome to God's country just in time for winter Seriously though....how cheap is rural/regional.
    • Thanks guys! Some pics attached 馃構
    • Big enough for you, Jackie, and some puppers mate! I vote some GSDs, but I am biased   How big of a block is it on?
    • Well, fun day was had, I finally found a house that will do me just fine, 1980's brick build, but with full fresh renovations, plus new colour bond fencing all round so puppies are incoming 馃悤, and water tanks for the garden, and it's located in West Goulburn..... @Duncan 馃, so day trips to Wakie to watch cars going Zoom will be on the cards In the end it cost well under my budget and was actually better than alot of the more expensive joints I was looking at, it is in a good area, close enough to the shops, public transport, and the Wollondilly River Weir,  and the great walking paths along the river, but far enough away from town to see minimal traffic The deposit is dropped, the conveyancer is conveyancing and I should get the keys in a week or 2 as the property is currently unoccupied  As with everything I own, I'm doing up a modifications list, as it doesn't have solar, that is first up on the big list, all of the panels and enough batteries to keep the joint warm, or cool, followed by a largish carport out the front, the small list, which will start as soon as I have keys, is some security stuff, like cameras, screens, and the usual "crazy prepper" additions that weird old people like (mouse holes to stick shot guns out of, and the usual man traps that the average person installs for the unsuspecting and unwanted guests 馃ぃ) The gardens front and back are OK, but, not to my standards or liking, so landscaping will be a fun job to start getting into, so when spring is sprung I'll do a heap of planting, lots of natives and vegetables is the plan, the old owners were more "Old English Garden" type, so basically Roses and other weird looking things that are destined for the green waste bin One thing that is staying garden wise is a nice established hedge out the front, it is about 5 foot tall and covers the whole front of the property from prying eyes As for the car hoist, the roof in the garage has some height to it, but, I'll need to get an installer out to see what can be done, width wise may be a issue, but my building inspector will be getting back to me over the next week with his recommendations  Small, but cosy
