hey guys i was really interested to know if anyone can double check for me if turbos from auto r33 gtst's are/look different to manua r33l gtst's?
i bought one and it looks like this.
now can someone tell me if this is an r32 gtst turbo or possibly an "auto r33 gtst" turbo.
i have heard this in a couple of cases where the auto r33 turbos look different to manuals but looks similar to r32 turbos but with bigger compressors or something along those lines? do series 1 or 2 matter also?
can anyone confirm?
Edited by jakez88
fyi
the turbocharger on the auto and manual GTST (of the same model) is identical
ie nissan did not make different turbocharger models for auto and manual
they did, however, use a different actuator spring on the auto turbocharger
this is because the AUTO gtst runs less boost than manual from factory
from paulr33.com
ECR33 manual is 385mmhg which is 7.4446 psi
ECR33 auto is 270mmhg which is 5.220 psi
ah fair enough thanks for that paul. so this is no doubt a r32 gtst turbo?
here are some pics of the rear housing. bigger compressor then normal?
sorry about the crappy pics lol.
Ah awesome. Thanks for tht stao...its actually going on a rb20 so should be good. Thanks heaps...looks like I got bargain lol
  On 26/02/2012 at 10:08 PM, hypergear said:
you can, if you can drill out the oil restrictor on the hollow screw and the benjo. not recommended.
Thats what I have done, been running fine for over 3 years. You just have to be careful of how much you drill into the banjo, as it doesnt like too much or too little oil, esp if its journal bearing.
  • 10 months later...
@paulr33 I beg to differ about the boost levels between the r33 auto and manual. I drive a auto, and before I put a boost controller on, it was boosting to around 7psi in high boost mode. Which should be just over halfway on the stock gauge.
Says it all. High boost Mode would've had the stock solenoid hooked up which gives 2psi extra.
My car was auto from factory but converted to manual, boost was 5 & 7psi and 7psi with high boost mode.
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
