nah dont know specs, its a T04E, is on an HKS manifold with HKS ex gate so is pretty big. its laggy but not too bad. it starts making boost around 2500 but thats like 01-0.2 bar but gets up to my 08.bar at around 4000rpm......
are you running a metal head gasket or forged pistons to take it to 18psi? i know their efficiency range is around 18-22psi but i cant take mine that far with stock injectors and internals....
I will run RX7 injectors, internals are supposed to be good for 250rwkw, i would likr to get 230rwkw and will run up to 18psi for the steet. Mine is a TO4e as well, its the smallest fo the T04's they make and is not that big compared to the others.
Once I have everythink runnikng i will probably get another engine built a bit stronger depending on how it runs. Metal head gaskets are not required as much on RB20's due to their lower compression and it it is tuned right with no detonation it should be fine, hopefully.
217KW SPECS
FMIC
3.5" EXHAUST FROM TURBO
VG30 TURBO
1 BAR BOOST
S-AFC
BOSCH 910 FUEL PUMP
HKS CAM GEARS
ADVANCED IGN TIMING
HIGH OCTANE FUEL (70% ULTIMATE + 30% TOLUENE)
DCS HEAVY DUTY SINGLE PLATE
206KW SPECS
FMIC
VG30 TURBO
1 BAR BOOST
S-AFC
BOSCH 910 FUEL PUMP
Don't forget that the clutch makes a big difference as you have to be able to transfer the power to the wheels. We drove my mates car on the road and the clutch seemed OK but when we dynoed it it only made 213rwkw then we replaced the clutch and now it makes 231rwkw, a similar thing happened to me now my car feels a lot quicker as all my power is getting to the wheels.
I will post the power figure with the cam gears and normal Ultimate fuel once I have it de-tuned for daily use....still have a bit of the good fuel in the tank so I want to use it up :)
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
    • Emissions, fuel consumption, heat, noise, etc. most likely.
