U may need a mew cas bracket also. I have had one car give countless issue's which was caused by a welded up cas bracket.
If it isnt perfect the disc inside the cas may not be running true to the optical sensor
Yeah i think i will get a new one, i put it on and it was not lined up so i put a washer behind one of the bolts and it made it pretty much spot on, put the cover on with a new CAS gasket and it started up first time and sounds good, hopefully it will keep running and the problem has gone.
The idle speed/sound kind of hunts a touch, i think it maybe just the cams or a very small vacumn leak.
Thanks for all the good advice people :cheers:
Massive facepalm moment today, was driving it for over an hour without major problems, the idle was a bit shaky but was driving and seemed good, then all of a sudden pop pop pop pop goooone.........:rant:
Dam CAS!!! or bracket , i could of sworn the thing was on properly this time and done right. i am at a loss to what is happening with it.
Can someone confirm wether the tomei cam is longer than stock? im thinking it either was in there too close or the keys were not together properly.:(
Edited by SliverS2
