Hey Guys, as above, Can i run a blow off valve setup off the hot side of the cooler setup on a 26 rather than the cold side. Installed a 26 in my R33 Gtst, and am having problems with the bov return pipes.
Would make life easier if i could run BOV's on the hot side and get them plumbed in there too..
Whats your Say on this guys?
Cheers
I was running a vented BOV on the hot side, right infront of the turbo actually. I took it off the same day I fitted it on, mainly because I hate vented BOV's. It worked just fine. Plumbing back a BOV back onto the hot side hmmm kind of sounds weird to me but that would be very interesting...
I dont see why not. Its doing the same job regardless.
Just seems like most BOV are as close to the TB as possible.
I have seen a GTR with custom bov return. They just made a pretty stainless pipe up that went between the head and the radiator. Looked good. Cant seem to find the picture anywhere though
In short: "I installed a bov and then I took it off on the same day, because I hate bov's"
Some people have weird ways of passing time..
OP, you can run it on the hot side its fine. In theory the closer it is to the throttle the better but I've never had a problem with it on the hot side and many brand name parts come in a kit on the hot side. Whatever really..
Just had this debate. I reckon nearer the turbo rather than nearer the throttle body but where ever it is I suspect makes very little difference. Some people have it on the hot side some on the cold side some manufacturers stick it on the intercooler so what ever suits your needs or tastes will be fine.
This one?
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=110483
Tried to embed but I'm on my iPhone and it's all too hard.
Some guy gave it to me, it came welded onto the standard hot pipe to be a direct replacement into the R33. He said they don't sound like the other high pitch BOV's. I tried it out, didn't like it, sold it lol. Turbosmart, turbofart.
Was it the 'rattle snake' one? I like that one better than most but still not a fan of atmo's.
In my case it's stock GTR or nothing.
Its taken me a while to get what you're saying but I don't think (hope not) that the OP is planning to plumb the bov back into the hot intercooler pipe but into the turbo intake on that side of the engine!
It would work but maybe not as well as just before the throttle body, may get a bit of reversion.
When I went forward facing plenum in my 32gtst (custom setup, not GReddy so didn't go through the battery tray), I fitted a full 32GTR cooler/piping/bov/recirc setup. Really nice solution!
With the 34 I will do the same but just run 2" pipe straight across instead of the molded plastic GTR recirc pipe :thumbsup:
    • Saruthewhite hasn’t been on our site since November 2016 sorry mate
    • Note when Duncan says that, he means "when you're not using the correct lifting points on the sills, because you want to work on the sills. A 2 post hoist is not appropriate for everything anyway, and working on the sills is a good example of that, because the arms go under ths sills anyway. You're better off finding another way to support the car off the ground. Beyond that everything else D said is correct. Only the dedicated jacking points are the correct place to lift. Anywhere else is incorrect, extra caution and awareness must be used, etc etc.
    • Your off site links didn't work for me, and in any case it is easier for forum members if you post the pic directly either as an attachment or a link so the information is all in one place. That aside, the sills are the correct place to lift the car, whether with the factory jack or a hoist. Yes you should use rubber blocks with a slit for the seam on a hoist to avoid bending the pinch weld (where yours is currently bent, just bend it back if possible eg vicegrips), and be aware of the height you need in the blocks to clear any sill extensions to the hoist arms as it lifts If what you are doing needs access to the sills, the rear subframe bush would also be strong and secure. I'm not sure what you mean by sidemember (maybe same part I mean by sills) but be careful that your front support point is not too far back as the car is very front heavy and could overbalance.
    • Here's my first iteration - white duct tape so color is off, but this is just a straight line across the bonnet lip. From a geometry standpoint, this is probably closest to what a GTR has. Next up is some $5 white pearl vinyl and some rubber door sill trim, applied to the BACK of the bonnet lip. It's more accurate placement to the GTR, but also follows the body lines on this setup a bit more. Couple more pics on this config incoming: Again, a $5 vinyl and rubber job, it's  POC still and not how I'm gonna run this part. But one thing I'll note is that the black trim does need to "straighten out" a bit, and instead of going completely along the line of the bonnet lip, might be better suited to wrap over the "horns" of the bonnet lip, giving it a less aggressive curve up at the ends.  The correct way to do this would be to paint it body-matched and then decide how you want to make the black line. If you used paint or a pinstripe, you could have the black line go straight to the corner of the headlight where the rubber strip typically meets the headlight on a GTR.   Hope this helps!
