  • Replies 111
does it have a Silver & Red sticker on it with AS1698 on it (or a Snell or equivalent sticker) and is it in good condition (no cracks)?
Quick question, I'm looking at coming to the next DECA coming up but I only have a Fox V3 helmet, would it be track legal?
Helmet
Want to thank every one that took me for a spin during the afternoon battles. Special mention goes to Ash and his GTR, my first time experiencincg a GTR launch and wow... And also to NutR33, what a mental ride. Such a fitting number plate, both you and that car are definitely nuts.
Just wanted to say thanks to all that made the day possible.
Also a special thanks to Russ for the quicksteel and Luke for the assistance when I cracked my radiator.
A lil disapointed that I only got one run on the wang, but was great to be able to get out onto the skidpan in the arvo.
I'm aiming to get to all four DECA's for 2012... with a new radiator of course! haha
Marty... can you please message or post up any links if you come across any video of me on the skidpan? :rolleyes:
What an awesome day it was, pity about the heat but it didn't seem to affect too many cars.
Thanks to all that help make theses days happen, most importantly those like Wayne, Julies, Anna and all the other volunteers who stood out in the sun all day for our enjoyment.
My highlight for the day was drifting the hairpin on the mini Wang and then 150+km toasting the rear tyres on the long wang, stupid but fun at the same time as I think Femno who was in the car will agree.
If anyone has footage of my car feel free to post it on YouTube, just tag it as NUTR33, there is a bit of a collection starting there.
Cheers Luke
Woohoooo I AM ALIVE!
An awesome DECA, I must admit I was ready to call it quits by lunchtime and was feeling preety average (No- I didnt drink the night before!!) so the shade tent on the pan although it was trying to blow away was such a great idea. Thanks to all for their hard work in completing another round successfully :) Without the volunteers and organisers things like this wouldnt happen. Was a great change sitting around drinking/eating pizza and talking crap most of the night at the motel Saturday night too, quite enjoyable and allowed us to get to know a few of those who we didnt already know.
I wont be around for round 2 (booo!) but look forward to round 3!
P.S I am starting a "NUTR33 DECA tyre fund" any donations/sponsorships welcome :rofl2: :rofl2: :rofl2:
Thanks to everyone - fun day even with the heat!
Props to those who stood out there in the sun. I've done it before, and it's pretty full on.
Rear diff is 100% farked now. Single spinning all over the place, made skidpan stuff a bit of mission impossible...
Will have that fixed before the next one :)
So seems work activated a nice new Internet connection...so I thought best to test it...
anyhow 14 gig in a morning makes me think it is now ok for the rest of work to use.
http://sau.loudsx.com/DECA%20feb%202012/
will do low res ones tomorrow as well basically I cannot be bothered today.
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
