  • Replies 111
Don't worry I agree wholeheartedly - to be able to win on street tyres in a virtually unmodified car there has to be cheating going on. Some consistency / conservative driving, but lots of cheating!
I just dread the day I get behind a RWD and you all get to really see how much I suck at driving!! Going to be like starting from scratch.
Dont have excel @ home... anyone enlighten on how bad my fail was? :)
I wouldn't class 8th Overall as a fail Ash! :thumbsup:
So I did some shuffling around with excel...
If I exclude results from the events that I didn't run (only half the events thanks to my radiator), I then come from 37th up to 22nd overall.
Then if I go one step further and look at just RWD, I finished 11th out of 30... Sounds good to me! :laugh:
Oh, and who was on the clock for battle 1... Apparently I pulled a 29 second run on my first battle???
(although means nothing coz I nudged the cone in the finishing box!)
Bring on round 2 already!!!!!!
Thanks dude :thumbsup:
I'll class that as a reasonable, still fail though. Trying to do better than 3rd AWD this year and epic diff fail hurt me :D
Loving the mega mini wang though. More I think about it the more fun it was.
Half because it was new, half because its quite challenging compared to the other events. Sooo much gravel
The 0 points for a WD really hurts now, still 11th is my best result yet, thank you twin turbos :worship:. still plenty of improvement possible, looks like i still need to show a bit more commitment on the wangs.
congrats to the winners :thumbsup:
    • https://www.efisolutions.com.au/coolant-temperature-sensor-bosch-180sx-s14-s15-r33?gad_source=1&gclid=CjwKCAjwzMi_BhACEiwAX4YZUHsCQhbiDT_NC3q5wD9jrzH6Dts9eGSr19NXSDw7x9WVm1sH7G3S4hoCwaUQAvD_BwE this is the one i replaced today
    • I have replaced the larger coolant temp sensor, i do see a smaller one next to it (looks to be just 1 pin) but i assume that is just for the dash? or should i replace that aswell?
    • Check coolant temp sensor ~ symptoms fit the hard hot start/cold start OK scenario --- if sensor goes open circuit, ECU thinks engine is cold and enriches mixture ....works when engine cold, but floods them with rich mixture when hot (Hyundi MAP engines are a bit infamous for this)...
    • OK, starter changed for a spare without much trouble. Neil had kindly left space to get to the top starter motor bolt from above with a long spanner which makes the whole deal much easier, and everything else was neat and easy to get at from underneath. Once the starter was changed everything was good, unplugged the CAS and turned the motor on the starter to make sure everything was free and happy. Onto properly priming the oil and first start. I'd picked up one of these oil prime kit from Boost doc a while back and this was my first time using it.  https://boostdoc.com.au/products/engine-oil-prime-kit?_pos=1&_sid=28c628a65&_ss=r While I'd organised all the fittings to hook it up to my GTR (sump plug to -6 feed and -4 T to tap it in and retain the oil pressure gauge, neither suited on this car as the oil pressure needs to T into 1/8 NPT not -4 and the Aeropro sump has some massive drainplug not that factory whatever it is. So, waiting for a couple of fittings, then I'll prime it and do first start, hopefully next weekend. Other than that going well, there is very little stopping a final alignment, tune then shakedown day
    • Also to mention, i just tested the CAS, seems to be working fine, can hear the pulses inbetween 0 and 180 degrees, another mention aswell, when i let the car sit for about a hour today, i went to start it and it almost fired on first crank, then just completely struggled. Could it possibly be blocked injectors?, maybe allowing a little bit of fuel to seep past allowing it it almost start first crank?
