best last night for me was 11.3sec again, but this time with a 127.5mph....7500rpm clutch slip seemed to work good and not bog down....traction was abit of an issue though :/
going drags is getting addictive
11.3 sweet and 127.5mph is quite high and good for a very high 10
I have a set of stock 32 GTR rims with Toyo TQs your welcome to borrow next if you like, was going to bring them down last night but got caught up with some family matters and couldn't make it, they do a good job of holding traction
What brand tyres where they cheapies or actual quality?
Reason i ask is my mate cracked a 12.3 on a 34R with nothing but 1.2bar boost on the stock ceramics and a full exhaust with Bridgestone RE01's (still running std injectors, fuel pump, ecu). It was only about 255awkw from memory too.
there 265 sorry and kuhmo ku31 brand new, very grippy, but i know what you mean about standard turbos running low 12's hence my other thread ive started
im onto it lol
Cheers buddy, will definetly keep it in mind for next time I go, maybe in a month or so :)
  • 1 month later...
Launched by 260rs for the first time last night, 3 big revs up to around 7000rpm let the clutch out spun the tyres for a sec then hooked up, did 3 passes with 1.9 60 foot best time of 13.2 @102
Can't wait to screw some more boost n fuel into it and give it another crack
was that at willowbank? i never saw any stagea's there... was a angry XR6 doing low 11's with lots of wheel spin though
Yep shure was! I wasn't there long, got there when the gates open did 4 runs before 5:30 and left soon after, was that the green xr6 ute that was fish tailing the whole track?
Edited by GTR260
  • 1 year later...
Great thread, I have been practicing doing soft launches at 4k to 5k and now I have the car responding better it is great feeling. Done about 30+.
I only have 345AWKW but set up and tuned for response, have an OS Quad clutch and I wait until I feel the clutch start to bite and let it go, it seems to work fine.
Been very worried about stuffing the box up but from what I have read I might build the revs to 7k and see what happens, then maybe more if everything is still in the right place LOL :)
Been told I would be better of with a Nismo coppermix type, twin or triple as they are a bit more forgiving when launching on standard drive-line
Any help appreciated
Still need to start somewhere, I know SFA about launching a R34 GTR and what the driveline can take.
Motor,clutch and diff no problems. BUT gearbox and drive shafts ????
SO your advise is go hard every time and hold on, YIPPEEEEE!
Sh@t you blokes must have a S load of money.
I just love that advise, that is what I want to do , BUT I would like to know what is a stupid way to launch and what is a better way, well, and be able to do it often.
I just thought that my car is not a 1000HP beast I can still have some fun with 345AWKW without FNit it just for fun.
So any educated guesses welcome and after I stuff it up what are the best gearbox setups to get LOL :)
Hmmm. Now I don't own a 345 kw gtr but I do believe I own a 340kw gtr. Oh I've also launched it countless times at 7k.
Also, if you do some more research you will find that the driveline is very strong. However, if you don't preloaded your driveline prior to launching then there is a much higher probability of you breaking something.
Hi, I did a bit of research and like everything with this type of thing, 1/2 say do this and the other 1/2 will say the opposite, so ????
You say you have a 340AWK GTR. I would guess mine could be more responsive than yours and there is not much difference between the KWs 345 & 340 but I had them modify mine for response and not worry about getting high Dyno readings .
When I bought my GTR it was 337.9AWKW, I expected great things, got crap all and I did launch it at 8k at least 10 times and it was still laggy as sh@t and without launching it the worst car I have ever driven for response and I have owned some heaps of sh@t in my life. BUT I must say once the T78 kicked in it was mad but not a DD machine.
I do the same launch now, get the revs I want , let the clutch take up the slack and let it go, I have to say with the Quad clutch there is not much slack to take up ,lol.
Since I modified my car I can do the same thing at 4k/5k and it is so much better than the 8k as it was before I had it modified and tuned for response.
I think I used a little common sense when I launched it from the start and loaded the driveline, but at that time I did not know what a driveline or loading it, meant, it just seemed a smarter thing to do rather than just booting it slack, sorry I do not know the terminology for this type of thing
These cars seem to be exceptional and totally over engineered from the get-go to be able to do this type of thing to them and on a regular basis .
Thanks for your input it all helps me get a better idea about the R3s
I have a R34 GTR with a 3.0ltr making 458kw at all 4 with a triple plate Exedy and stock Getrag 6 speeder that just ran a [email protected] after weighing in at 1661kgs with out me
My cars is more responsive with more power and torque every where then yours
Dial in 7k get clutch to friction point loading drive line then progressively release clutch while pushing down the loud pedal in a balancing act to keep it on song, you ideally you want a bit of wheel spin to stop it bogging down
NEVER EVER let the clutch go from the floor boards by moving foot sideways cause that is a sure fire way to brake something
That what I have learnt from years and years of launching both my R32 and R34 GTRs, like previous info ive given you can use it or not
  • Like 1
Sounds good XKLABA and with the power you have I should not have a problem following your advice, saying that, cars are cars and anything can happen but it takes some of the unknown away.
Even at 4k ish I have been getting a little spin and it has been taking off without bogging down since my my new exhaust system was fitted. I will let you know how the 7k launch goes later today :)
It was also suggested that a softer clutch like a Nismo Coppermix, twin or triple would take a little stress off the driveline, maybe after I have used the OS Quad up I will go in that direction.
Great advice and this thread is very helpful for us newbies.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
