Hi Mick, it was too late for your advise but you were spot on, did the 7k launch, on practically new Perelli 255/40x18, crazy span all 4 through 1st, fishtailed a bit and into 2nd span some more let it off a bit and away it went.
I then did it at 6k and that was a better, still too much , 5.5k worked the best, just enough spin, then off it went.
The AWKW is not much more than with the original T78, 7.6 AWKW extra with the PT6262, Poncam B, new exhaust and tuned for response, but it is just such a different car now :)
Thanks again for your constructive help. So many just say take it to 7k or 8k and step off or drop the clutch and that was not helpful
Pete
haha yeh Mick, just a street car for an old bloke but still fun..
Do you know anything about the HKS Turbo Timer, it seems to have a timing capability , not sure how accurate they would be but somewhere to start I guess.At least I could see if I was getting the times down??
Might try and do a day at Eastern Creek on the ARDC days, but getting there is the problem, got kids to look after and 4 hours to get there, have to spend a day or 2 in Sydney
I will keep up the practice and see where it leads :)
I'm gonna guess mid-high 11s with a good run given your setup and the tuner
It seems that once you get to a certain power, it then takes a lot more to knock off a second and heaps to get under 10 secs.
Your car is about 100 AWKW more than mine, what does that do the 1/4 in?
It seems that once you get to a certain power, it then takes a lot more to knock off a second and heaps to get under 10 secs.Your car is about 100 AWKW more than mine, what does that do the 1/4 in?
I have a R34 GTR with a 3.0ltr making 458kw at all 4 with a triple plate Exedy and stock Getrag 6 speeder that just ran a 10.8@132.23mph after weighing in at 1661kgs with out me
:thumbsup:
:thumbsup:
That is what I mean, with that power 458 AWKW doing 10.8 and your R32 at 293AWKW doing 11.13, 1.5 secs difference and 165AWKW to get that 1.5 seconds
What would you have to do to get under 10secs ??
It's actually 0.33 of a second difference but that run was only 24psi 436kw not the 28psi that did 458kw, there is a 250kg difference between the two cars, it's the MPH that tells the tale of power difference
The 32 is really just a freak of a car that I have been racing for over a decade so I know how to get the best out of it and with a bit more setup and seat time I believe there is another 0.5 sec to be had from the 34
Brb just going to have a look at the TT now
Ok so get yourself onto your "private" road lined up ready to go
Then on the display from where the count down screen push the M button 5 times, it will most likely come up 0- 1, then push the S button to scroll through till you get 0- 4, once that is displayed in a few seconds it will start beeping and flashing once that happens you are all set and it will automaticly start timing as soon as the start to move
Note, you MUST have the rpm and Kmh hooked up and set correctly
There is a lot more to these cars than I thought and very interesting.
I am lucky to know people with private property and a quality road to use but I have to tell the family when I am doing it :)
As soon as I get a chance I will follow your instructions and see how I go.
Thanks for your tip
I am having trouble with this laptop hope this gets through. hard to login and post.
I am lucky to know someone with property and a good road to have a chance to get some short runs in :)
Thanks for the tip
    • Well, in the same way that you can't tell any SUV from any manufacturer in any size category from any other one, "sports" coupes now all look identical. Stand back and squint your eyes and the Supra and the 400Z and the GR/BRZ things all look the same. I was just thinking last night, when sitting behind a Subaru CrossTrek, that I have no idea what it is, how it differs from an XV, or a Forester, or an Outback, or anything else Subaru offer, and I couldn't tell if it was supposed to be small, medium or large. I contrasted that to the good old days, where a HQ Kingswood had familial similarities to an LJ Torana, but there is no way that you could confuse them, and how a bit later, the HX Kinger and the concurrent Torana and the Gemini all had familial similarities, but you still could not confuse them. Ditto the ugly Fords and Chryslers of the era. But now, a RAV4 looks like a Kluger, looks like a Yaris/Cross/whatever they're calling those stupid f**king things, looks like every other Toyota that's not a Camry/Corolla sedan.
    • The Prelude doesn't look that bad without all that lens distortion in those pics. Makes it look disproportionate when it isn't. Actually I kind of liked it at the Osaka Auto Messe earlier this year.
    • Pour in the highest octane, non-ethanol fuel you can get and see if the readout changes. If it's dead bang on 11% then I would question the sensor. Another quick test, just take it out and run normal (in an american accent) gas-o-line through it and see if the sampled ethanol or lack of changes.   United E85 here in the land of drop bears does vary a bit, I've had as high as E87 (could be water in their tanks too, who knows)
    • Yep. And if you ever do, you'll just have to deal with it then.
    • E10 is pretty tightly regulated in percentage. Too much and engines can't adapt. Every incentive is against them to have too little ethanol though. The more ethanol the higher the octane.
