My Baby Is Hurt
bra0063
 Share
hi guys as you can see there is a faint z shape on my bumper where the paint has been stretched i have used a hair dryer to try and soften the paint with no success anyone know anywhere that can fix it or any methods to try and remove it other than slapping stickers on haha.
cheers,
Edited by bra0063
A cheap option that you might try is to buy a "T-Cut Polish" that is of a colour like your own.
It tries to apply colour as well as polish > blends in.
Might be at K-Mart or Supercheap.
so its not like polyglase or kittens heavy duty cut and polish?
No it's actually a polish with tint in it.
I've used it on a red Mazda before that was scratched up by a cat. The red "T-Cut" polish blended over 85-90% of the scratches. It would then need sealant over the top to harden.
oh ok what type of sealant just some polish??
Once you've used the white or silver coloured "T-Cut" polish to match & cover up the blemish > buy some sealant from Auto 1 or equivalent.
The salesman will know what a sealant is.
You only apply a little bit. A few drops go a long way.
Let the sealant harden for 2-3 days, then finally apply wax (Canauba)
If you don't apply sealant, the chances are, that coloured polish you applied can gradually come off.
Is it a solid white? Or metallic? If its solid, honestly, get a tin of ur paint mixed up at autobarn, $30 and a sheet of 1200 wet n dry. Scuff up the bar, lightly, mask up, spray, and let dry. No blending required. Its white. Guaranteed to fix the marking. Allow to set for 48hrs, light rub with the same sheet of 1200 then polish. If its a 32, the white code is more than likely 326....did this to my baby a few times.
 Share
    • Shaft speed would be the same, however it's how long they hold it there for and repeated conditions. FWIW half way down the main straight at SMSP I'm bouncing off 4th with a 8600RPM limiter. That shaft would be spinning at 8600RPM for a few seconds before I need to smash the brakes, by T2 it's getting close to that speed again. Now a drag car/roll race car would see that shaft speed for a 1 to 2 secs then they would coast, hit the brakes and that's it.
    • With same diff ratio, tyre diameter and road speed, the tailshaft rpm is the same regardless of the gearbag's ratio. Given that very quick drag cars are probably doing similar road speeds to the fastest circuit cars (circa 300 km/h), and there will be many of either category that can't go that fast and so you'd have inummerable matchups between drag and circuit car speeds at smaller numbers, and given that they are probably using rather similar tyre diameters and probably using similar diff ratios, and...where any of those numbers were different they could quite easily be in opposite directions thus cancelling out.... I think you'd find that there'd be more similarity than difference in tailshaft speed between these two use cases, no?
    • they might see those prop shaft speeds for 1 to 2 secs only
    • A year of slogging through this bearing issue and finally fixed. What a nightmare. The oil pressure increase did not fix the problem. If you would like to read all the details in case you ever run into a similar issue visit my thread on Yellow Bullet. https://www.yellowbullet.com/threads/continuous-rod-bearing-issues.2689569/?post_id=74193031&nested_view=1&sortby=oldest#post-74193031 In the end the rod bearings themselves were the issue. I had switched from ACL (first engine) to King because that was all we could get at the time and I thought nothing of it. Put the ACL's back in after a year of taking the pan off multiple times to change many things. Issue resolved. Can't believe it was just the bearings themselves all along. It has now been about two years since I drove the car on the street or had it at the track. At some point I had installed all solid and spherical bushings in the rear but had never aligned it since it just went on and off the dyno. Alignment was the first thing to do. (Old photo but same concept) Then I took the transmission out and went through it. This was my first gearset install and I've done about 15 since this one and learned a lot and wanted to apply some of these tweaks to mine. The aftermarket shift forks take very well to some modification and I wanted to make that change. Shifts are now super smooth and no having to find the gear. I also recut the 5th and reverse shift sleeves - always wanted to try this and see how well it works. It works very well! No grinds or having to do a second attempt going into reverse and 5th is perfect. Before During After Going back in In rummaging through my spare trans parts box I found the only parts I've ever broke on a stock trans; the 3-4 shift fork - twice!
    • It also depends on gearbox ratio. Those drag cars running 7s passes aren't doing it on an overdrive gear ratio (probably). 1:1 is "fine", the critical RPM for a 50' single driveshaft in chromemoly is 6900rpm.... ....but when you shift into 5th and use 0:73 or 0:8 it all changes. Do you know their rear diff ratio? etc. That's the stuff that matters with regards to it. Whether it actually matters given your use application is also relevent. You may never get into those scenarios, like most ruined GTR's from Western Sydney don't :p
