My car has lost about 85hp at the wheels, thought the motor was getting sad, but got the leak down test an compression test done both came back fine. tune still seemed good just missing power (from 385 back to bout 300)
wondering if anyone had any ideas wot it could be? thank in advance :thanks:
https://www.sau.com.au/forums/topic/393002-wheres-the-power-gone/
Might get them to pull the exhaust off an see if it makes any difference, could be possible.. tho is there much to collapse in a 3inch metal cat..they are nearly straight thru. Wot could get stuck in the intake? hopefully the air filters get rid of anything big enough to clog an intake pipe. Dont think it would be fuel cos its a noticable difference on the road an it just dont go as good as it used to, an was the same dyno. but will get them get them to check out the exhaust. the turbo's are bout 2-3 years old garret think they're -5's running 20 psi is it very common for turbos to shit emselves or something cause them to run inefficiently?? Havent eva noticed any wierd noises when boosting. just dont seem to get the effect they used to give. something seems to be choking the engine somewhere.
lol I pulled my intake apart on my 32 for shits and giggles and found my missing 13mm spanner in the BOV return pipe??? !!!!
85kws is a big lose, maybe a hole in the intake pipeing or small hose come off, any black smoke under full boost?
Depending on your set up - oiled up AFM's will have that effect. If you are running a recirculation system for blow by gases and it is leaking oil out the bovs (common on GTR's) or you have re-oiled a foam air filter there is a fair chance the AFM's are messed up.
This causes them to read high - the consequence being single digit AFR's, less ignition advance and no horsepowers.
If you had it on the dyno what are the AFR's?
have got a vipec ecu so no longer use the z32 afm's (i should pull them off an sell them..if they're worth anything 2nd hand.)
Car was dyno'd this afternoon, an mechanic thinks its a clogged exhaust. so they gunna take the cat out in the morning an re dyno it to see if thats the prob
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
