Alright who's going?
http://forumbattle.com.au/
Saturday $37.50
Sunday $37.50
3-day $73.50
3-day seating $160
Serious SAU cars turning up.
So instead of bitching and moaning about it and spending the day at home letting your mum braid your hair, get the fug along!
I'm going Sunday.
The pictures on the Advan Yokohama site are a little out of date, so the mandatory carbon teaser pic...gallery_709_1130_297743.jpg
Also see BIG RED & Adam in action @ Calder Park!
Chris - R34 GTR
Stephen - R33 GTR - Yes those are twin 3037 high mouts :wub:
Dennis - R32 GTR (Competing in Street Class)
Anthony - R34 GTR
Last, and by no means the least... These two awesome machines.
Gerry's awesome C110
& Gerry's brother happens to be bringing along one for good measure!
Stefan - R32 GTR
Jonno - R32 GTR
Derek - R34 GTR
Scott & Johns R32 GTR (Winfield Replica)
Daniel - R34 GTR
Marc - DR30
https://www.sau.com.au/forums/topic/393062-forum-battle/
  • Replies 40
Any more info on this?
Youtube "BIG RED", or just look on the main SAU News page, has links embedded.
Lot of work gone into it over the past 4 weeks to have it ready for this weekend, and still lots of work to go :D
Paul - best day for racing stuff (forum wise) is Sat.
Sun everyone is stationary. But there will be other ARC stuff going on so Sun might be better for that?
https://www.sau.com.au/forums/topic/393062-forum-battle/#findComment-6254241
Ah crap. I'm freakn working in NSW on Saturday. Fark!
Ash what are the Media requirements for this event? Is SAU allowed to GoPro up and publish on YouTube?
I'm just thinking Laith may want to drop some of the video into an SAU VIC TV ep.
I can charge up the GoPro's and set them to auto record when on, easy to use. Surely we need incar / oncar of SAU smashing the rest of the competition?
https://www.sau.com.au/forums/topic/393062-forum-battle/#findComment-6255273
John - NFI about requirements/restrictions.
Will be in Cheltenham till late. If you wanna drop them off i can just try organise whatever i can on the day.
Charging them I can organise tonight @ home.
Regarding S'n'S - Does anyone know if the cars need to stay at the venue the whole day? Or can we leave anytime after the judging?
Far as I know you have to wait until the end as we are in the middle of the Dome... You can't just up and leave when you feel like it.
However feel free to contact them directly if you need more information - they put contact details into their email on Wed or Tues.
https://www.sau.com.au/forums/topic/393062-forum-battle/#findComment-6257110
checked with Sean re moving cars for SnS, as long as you're in by 9am and he hopes to have the judging and what-not done by lunch-time, you're free to come and go (this has been helped by the change of locations away from the thunderdome, so they don't have to worry about rally traffic). So yeah, that's good, because i gotta be at work by 2:30! hahaha :D
https://www.sau.com.au/forums/topic/393062-forum-battle/#findComment-6259102
    • Sag as in the windows start to slowly open themselves, or they're just slow to go up/down with engine off?
    • It looks like it needs a big worm gear drive on it to control the rotating, not a few sloppy pins!
    • As Duncan said, first there was OBD, which few cars used, then came OBD2.   Now an interesting point, OBD2 isn't even for what you want to do. OBD2 is for emissions testing. There is some sensor data on OBD2, but it's up to the manufacturer what they're putting on it. Most scan tools operate on UDS, which like OBD2 is a standard built on-top of CAN. UDS specifies how to structure a message, what very limited things mean such as "read memory address" but it does not specify what is stored in which memory address, that is all up to the manufacturer. You either a scan tool compatible with that vehicle, or to know how to reverse engineer all the data, which can take a VERY long time and a lot of vehicles to get it right. Oh and then the manufacturer does a firmware update and changes what's where... Ask me how I know that as fact Oh, and by the time you've got the scan tool that supports all the manufacturers stuff, well, you're back at "But a consult cable and the Nissan software" The main difference being most manufacturers software these days works with the same hardware readers, as the readers are built to support J2534 which is another standard for how the PC communicates with the tool to make it do specific things on the car...
    • Rotisserie is fully assembled apart from centre connector which obviously isn't required until the car is on it. It packs away fairly neatly and doesn't take up too much room. (Now that I actually have some room after my clean up!) Overall very happy with the quality of it.  Assembly was a piece of piss.  The only thing I didn't like was that the pins that lock the rotation lock wheels in place were a bit of a dick in a bucket scenario. It allowed the arms to rotate a significant amount even when locked in place.  To fix that i measured up the hole and went and grabbed a couple of 18mm fully threaded bolts and a thread tap to suit. I ran the tap through top and bottom so it was threaded both ends.  Then just threaded the bolt through both sides.  It has made a massive difference which hopefully you can tell in the before and after video how much difference it made. 20250207_161431.mp4   20250207_161431.mp4 Hopefully back working on the car over the next few weeks.   20250207_162801.mp4
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
