hey guys was planning on keeping the ar but have just spend another 7grand in the last two weeks on the car so either wanna hang myself or sell the car!!
the car is basically brand new! fulkyl build engine 2000km old , autogallery yokohama gearbox 1500km old since full overhaul , brand new clutch 500km old , brand new turbos!! not even installed yet so 0km old!!
this car has recently made 405kw on a mainline dyno with trust t517z turbos , which are now sold and brand new garrett -5's are going on should still pull 380-390kw with a lot more response!!
engine
fully built engine capable of big power
block machined , balanced , honed oversized 0.20
crank , remachined and re heat treated , oversized acl race bearings
rods , shotpeened and prepped rods with oversized acl race series big end bearings
pistons arias forged 0.20 oversized with acl race series rings ect
tomei oil restrictor
cossworth 1,5mm drag series metal head gasjet (low compression suited to 30psi+!!)
n1 water pump
nitto high flow oil pump
nismo low temp thermostat
trust oil filter relocation
tomei sump baffles/trap doors
brand new gasket set throughout
head reconditioned with
hks step 2 cams and valve springs quite lumpy
slight porting on exhaust side
greddy adjustable cam gears
rocker covers painted in midnight purple
turbos , brand new garrett -5 turbochargers , $2500 last week!
hks non turbulent dump pipes
twin 3inch up pipes with 3inch magic cats (100cfm)
single 3.5inch high flow system
5inch rear cannon
autogallery yokohohama/os giken 1-5 gearbox , custom double cone syncros , hd mainshaft , hd input shaft , one piece billet 5th gear built by terry at award in sydney,,,
brand new os giken twin plate clutch about 200km on it !!! $3000 last week ,
vspec active rear lsd and axles ect
nismo 320kmph dash ,
apexi power fc commander with hand controller
blitz ebc
injector dynamics modified 1000cc injectors on standard rail
turbosmart adjustable fpr
bosch 044 pump
splitfire coilpacks
hks dli twin spark amplifier
this car has run on the dyno with several different setups , befoire engine was built was making 370kw @4 wheels on mainline dyno
and has made over 400 since the build
with -5 this car will be a weapon!!
exterior is standard with series 3 front lip and volk gtc in gold
also tien adjustable suspension
resprayed in midnight purple with more gloss looks beautifull!!
asking 32,000
also very keen on swaps +cash my way as i want to build a drag car project and need a street car!!
cars of interest , s15 , supra , jap imports hsv clubsport ss ect
also would consider swaps for a 32 gtr + cash my way
not lookign at upgrading so cash my way only thankyou!!
but please no gemini wagons or vt commodores with spinning hubcaps
do the maths , 22-25k for a standard gtr which will probably have problems , +20kish to get it to this level or buy this practically brand new car get in and enjoy!!
car hasnt even seen 4000km since engine was built including 1500km break in ,, this is a weekend only car for me
contact dino on 0434008133
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
