Tyre Advice
so they put the worst tyres on my car for the RWC when I bought it. Not too bad in the dry but downright dangerous in the wet.
it currently has 215/55/17 which I think is the standard size.
I am thinking about 225/45/17 on the front and 235/45/17 on the rear. Anyone running a staggered setup like this? any change in handling?
Edited by reverseworm
Stagged setup is fine.
What size are your rims?
i ran 245/285 and it was fantastic !
i would do 225/40/17 and 245/40/17
45 is massive profile !
I got 30 now and far too small. 35/40 is best i think.
You can't go choosing what profile you want to run just for the heck of it. There is a reason why a 17" wheel runs a 55 profile and an 18" 45 profile etc. its to maintain your overall diameter and ensure's your speedo still maintains accuracy.
Use this calculator to work out what you should be using. 215/55/17 is the correct base line OD you can use in the calculator.
http://www.1010tires.com/tiresizecalculator.asp
Also, if you are running the factory 17s, no point going stagger widths.
These tire profiles you quoted 225/40/17 and 245/40/17 are wrong and definately illegal if you are in QLD.
http://www.1010tires...ecalculator.asp
I understand that the rims are all the same 7.5 inches all round, but given it is a rear wheel drive isnt there an advantage having bigger rubber at the back?
Advantages only really noticeable if you are running wider rims on the rears like 9, 9.5 or 10" which will allow you to run anywhere from 265 to 285s.
In your case you are better off running a square setup and 245/50 all round or invest in a new tire and wheel package in 18s and try and get them in 9" rears at least.
Thats my opinion anyway but you are more than happy to run staggered, i'm just saying don't waste too much rubber on a 7.5" wheel.
Cool thanks for that.
I guess I also love the staggered look.
I have found Dunlop DZ101's 225 and 235 for $157 a corner.
Dont you think 235 might be a bit too wide for fronts? I could get the same deal for 235 all round.
yup 235/50 are fine too for front and rear..not too wide at all.
If looks are what you are after in a staggered setup, you will probably be quite disappointed because there is not much difference between a 225 and 235.
Edited by n15m0
by going 235/45 you have effectively decreased your overall diameter by approx 25mm to factory. In QLD the legal limit is 15mm, not to mention your speedo will also be out and aesthetically, the gap between your guards and wheels will also increase giving you the 4WD look if you are on factory suspension.
It was raining this morning and I came around a corner I have driven plenty of times before. I wasn't going quick but the back stepped out and caught me completely by surpirse. Before I knew it I was sliding sideways into oncoming traffic.
That was just too close for comfort so at lunchtime I went down and bought new tyres.
I went for Nexen N6000 235/45/17 all round for $130 a corner. They had some 50 series Kuhmo's but they were over $200 each.
In terms of looks, you can't really tell the overall diameter is slightly less - it doesn't look wierd at all. And i checked the speedo against the GPS and it is out by about 4-5 kms at 60kph.
Tyres feel so much better already. Thanks for your advice guys.
I thought you had to be no different than 30%...
where did you read 15mm?
http://www.tmr.qld.gov.au/~/media/c792a0c9-92b1-43ee-933b-7bdd8b20842f/pdf_modification_motor_vehicles2.pdf
Page 18. its 15 mm and usually works out to be approx 3% variance allowed...not 30%!
The rim diameter may be varied from the standard size but the overall diameter of the tyre must not vary by more than +15mm or -26mm.
These limits have been set for a number of reasons. Varying the overall diameter of tyres affects ground clearance, centre of gravity, brake effectiveness, steering geometry, performance and speedometer accuracy.
I've got the N6000 on my daily, a 5.7 litre commonwhore with plenty of torque and to be honest they're pretty reliable in the wet. They've not lost traction yet........................touch wood
If your car used to run the same sized tyre all round, and you run tyres with different circumferences front to rear then you can affect your traction / stability control and ABS (since they all rely on wheel rotation). Since that circumference is also not the same as stock, your speedo will also be out.
Staggering tyres is only useful if your car makes enough power to actually overwhelm the grip in the dry. In the wet, wide tyres is a negative to grip. Tyre compound and design will also make a bigger difference to grip and handling than the width. Buy a better tyre, not a wider tyre, if you want grip.
Unless you run a massively different tyre size, the aesthetics aren't even noticeable.
Depends how your car is set up, etc but summary i got was, yes wider is better but only is has the correct suspension set up correctly.
Think about what you said, which is "yes but only if X, Y, Z". In other words, the answer to "is wider better" is actually "maybe".
In practical terms, if you want to improve grip then changing the tyre compound and construction is far more noticeable, and with far less caveats, than changing the width.
 Share
    • Sadly, it won't happen. The AC controls in our cars are essentially on-off. Whereas the AC in new stuff is more a case of variable displacement compressors giving infinitely variable output.
    • I don't think anyone did. But it still made me consider. For me personally it wasn't clear whether the AC experience in my car was shit because it is an old system, or because it wasn't maintained. Looks like it may have just been the latter. I see some more modern setup being sold as an upgrade and I wonder whether it would make it drive like AC in a modern car. Where you don't really hear it or notice it. But maybe that's asking for too much as well.   Haha, stick it in a Nissan Cube and you end up with a driveable fridge I'm not doubting your experience. Just thought it was interesting to hear the AC technician's thoughts on it.
    • Guess I should be hunting down one of these big ol ford units then for max flow ....  I've had fresh gas in mine and it was never as cold as it is now . The compressor could have been trash though, like I said I am one example with a bunch of unknowns.
    • I don't know if anyone was seriously suggesting a retrofit of an Echo compressor in place of a more-or-less working original comp. You'd have to change the hoses at the bare minimum to do so, and that will definitely add significant cost. I had to get my hoses modded when I did the engine transplant and chose to use the Neo's AC over the even older R32 comp. That was startlingly more expensive than expected for what looks like a simple welding job, and a massive pain in the arse when it turned to have a pinhole leak in the weld too. The Frenchie's kit is for people who have next to nothing of the original system or have more than that but some of it is a bit shit and better off thrown away than salvaged. If you've got 90% of the system, you just patch it up. Mine is currently degassed because it apparently has a big leak somewhere. If I find it is the compressor, I will be looking to take my spare comp to a shop to assess and/or recondition, rather than contemplating a retrofit to anything off-brand.
    • I went and got the aircon regassed in the Stagea today and asked the guy about the upgrade to the Toyota Echo compressor. He was saying it is likely not going to be as good. It is newer but smaller and not going to pump as strongly. And it would be better to try and get a new OEM compressor. He was saying that the improvements people are seeing may be more likely due to regassing the system. I thought it was interesting to hear. Going by the sticker the system in my car was last checked in 2015. Gas was at 50% which is apparently beyond terrible. Under 80% is where efficiency already falls apart. Anyways, with fresh gas the AC is now bloody freezing. I think it may be working a bit less hard as well. I need to drive it a bit more to try it properly. Previously on hill starts it would utterly bog down the car. I'm hoping this is a bit better now. The frenchies kit looks great, but $1400 for the compressor upgrade alone makes it a bit of commitment. Very much so compared to a $150 regas.
