After finishing my annual shed clean up, I have come across a large number of various parts and accessories which I do not require and will not use. Everything is in good condition and was in full working order at the time of removal from the cars. For more information regarding the various parts, please contact me.
R33 Complete passenger side door - $90
R33 Carpet - $50
R33 Dash - $50
R33 Rear lights - $60
R33 Rear Window - $80
R33 Steering column & Boss - $100
R33 Door Cards (2 front, 2 rear trim) -$25ea
R33 Sub Frame & Rack - $150
R33 Nissan stainless steel cat back exhaust- $150
R33 Side skirts Japenese made - $20
R33 Front uprights & hubs - $50
R33 Side Windows - $25
R33 Rear Hicas - $20
RB25DET ECU - $100
S13 Exforce dat back exhaust system &de-cat pipe - $300
GTR Alloy Trust filters - $60
GTR Alloy rear hubs - $100
GTR front uprights & hubs - $200
GTR Air flow meter - $80
RB20 Air flow meter - $30
Z32 Air flow meter & Trust Filters -$350
AVS Wheels with brand new tires - $1000
Tial 44mm Gate (Brand New) - $350
Cusco Bonnet pins (2 available) - $50 ea
Trust 3.75mm Resinator Pipe - $50
Supra Project Mu pads (front & rear) -$200
RB20 & RB25 Cam covers (2 RB20 & 2RB25 sets available) - $40each
SR Coil covers (3 available) - $5 ea
GTiR Head Stud Kit - $100
Cusco WRX GC8 rad plate - $50
SR Cranks STD size (3 available) - $300ea
STD SR16VE crank STD size - $100
Strut Braces Front GC8 GAB - $50
Strut Braces Front R33 Apexi alloy brace -$50
Strut Braces Rear R33 genuine Nissan brace- $50
Some parts can be posted, others are pick up only. Please contact me to confirm for the part you are interested in.
https://www.sau.com.au/forums/topic/393176-parts-accessories-for-sale/
hey, ill take the Strut Braces Front R33 Apexi alloy brace -$50 if its r33 gtst?.. loox nice, and i so need one .. i can do pickup. im on the gold coast.. thanx
hey mate, if your willing to separate the z32 AFM's ill take one, dont suppose you got the plugs?
cheers
I'll split with you, I'm interested in the other then - do they come with the plugs?
Sent a PM about the rear strut brace earlier.
Cheers.
I have ur brace in bris now the AFMs are brand new one has a cracked corner and mesh on the bottom has a little dint no air filters they are $150 ea who ever pays first gets the one thats perfect but they are both new I have tomei plugs brand new if you want one $40 each
I have no Idea what part you are talking about are you asking about the trust filter and the alloy pipe which connects to the GTR air flow meter? If u are they come as a pair.
postage to Vic for strut brace?
Sorry i had the wrong guy you wanted nissan rear strut brace & Delivery $70 guessing the afm is to much for ur budget?
  • 2 years later...
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
