I get a lot of different opinions on the specs of 32 gtst injectors,
most of the confusion is from people trying too sell injectors for it but they arent legit and the size is wrong. (ebay etc...)
I know they are top feed
I do know they are high resistance, but how many ohms?
How long are they? Full? Half? 1/3?
What type of plug is it?
They are 11mm right?
Pressure 42 psi right?
Flow 270cc right?
Whats that other pressure rating about?(sometimes theres another one in the specs)
ANY other or more specific info would be great.
Any suggestions for NEW not second hand injectors would be appreciated.
Resistance.. I used 10ohm resistors when wiring in the GTR injectors, I think total the stock injectors are 12-14ohms
Length.. not sure, would say full (longer than my new injectors which are apparently 3/4 length)
Plug.. GTR is Bosh EV1 style and stock plugs fit GTR injectors if the locating tab is filed off.
I think they are actually 10.5mm not 11mm
Fuel system is a 3-bar system so with no vacuum signal you should be seeing 43-44psi
And yes, 270cc
Changing to a GTR style setup will open your options right up and it's just a small wiring change. I spent big dollars on drop in replacements but the latest setup I just went with second GTR injectors, made my own resistor box and made a whole new injector harness with brand new bosch plugs. Bang for buck :thumbsup:
I got my drop in replacements from Powerflow Injection I think they're called, supplied plugs too but they were second hand chopped off some loom they had laying around..
