flat bed tow truck?
that is unless you want to make it look like you are stealing your own car (window>bonnect>cut batt>etc)
or if you know who put the alarm in they may be able to help by pass it but still will be hard to move with out the key in the barrel.
Speak to a lock smith, they can get into anything they want. The dead-lock broke on the front door of my house so I arranged for a lock smith to come have a look at it. However I was actually away on holiday with nobody at home when I got a phone call from him saying he was at my house to fix the lock. Told him I was away for 2 weeks and he said no problem, he'll just let himself in and fix it anyway.
Scary thought, but there you go. Although I don't know if the same applies for cars...
barrel and all locks if you want to do it correctly but most people only do the barrel and drivers door lock.
Also is the car locked? seems a silly question but for all i know its in a shed unlocked and you have lost the key. Locksmith will help you get into it them replace the items with new key's.
Yeah it's fully locked. Not sure if there's any truth but I heard that of you remove the lock barrell there's a code on it that Nissan can use to replicate the key?
Also any ideas on an estimate for the new barrel, lock and key?
  • 1 month later...
Update guys. Got mobile locksmith to come out and cut a new key. My car dosent have chip in key thank god! Then towed to to auto electrician to re code alarm. That was ok could arm/disarm and crank over engine but couldn't start. The fuel pumps are getting no feed. Guy who installed my alarm did such a good job that any tampering/altering to system wouldn't work. Auto boys can't figure out what he did. Apparently my ecu is not giving feed to pumps. Alarm guy I can't get hold off was over 3 years ago and he was mobile service.
  • 1 month later...
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
