if i get my A/C degassed can i simply remove the condenser? or do i have to do more?
basically the A/C bearing was making heaps of noise, and since my cars a/c sucked balls anyway i decided to just cut the belt rather than spend monies to fix it. i can count on 1 hand the ammount of times i have ever used the a/c.
now i figure as it wont work, i might as well free up the airflow to the rad and around the motor.
im' not thinking about epic weight loss, and i'm not going to bother to remove the whole system, but i figure if i do it this way then i can put it back if i ever feel the need / sell the car
https://www.sau.com.au/forums/topic/393228-ac-removal/
i got a whole ac system at home if u need bits joe..
Otherwise just let the gas out slowly and rip it all out..
Not only does it make it easier to work on your engine but the weight savings are epic ;)
The fines for letting it out are big I hear.
Make sure you seal the pipes off so shit doesnt get in cause if not your kill a/c compressor should you decide to re-instate the unit.
https://www.sau.com.au/forums/topic/393228-ac-removal/#findComment-6254528
so if i have an accident and my ac gas spews out everywhere do i get fined for that ?
You drive a skyline? You'll get fined no matter what. Someone hitting you, gas spewing out..... But on a serious note, no, as it's un-avoidable....
On topic, yes. Get the system de-gassed and start un-bolting! Make sure you use rubber bungs to close off any open pipes that are exposed as crap will get in them and bugger the whole show if you decide to use it again. Also, if you don't run the compressor every now and again, the seals dry out or something and can leak when the system's re-gassed.....
https://www.sau.com.au/forums/topic/393228-ac-removal/#findComment-6254674
just crack the hose and let it out slowly. its highly unlikely anyone would notice it just makes a small hissing sound. if it starts squirting out liquids just tighten up the nut until it is just gas again. its not really any different to having a leak. im not sure if its harmful to us or not but simply dont stand over the top of it go to the other side of the car and start getting ready to remove the resy. im not 100% sure on this but you might have to remove the radiator to get the condensor out. then block the hoses and tie them them up so they arent flopping around in front of your radiator.
https://www.sau.com.au/forums/topic/393228-ac-removal/#findComment-6255295
its all lies..the reason the fun police dont want you breathing the gas in is because it gives an amazing feeling of euphoria and allows you to reach a higher consiousness where not only can you explore the possibilties of the human mind but you can make them a reality..if your lucky u may even meet a unicorn or pink elephant
Now that you know the truth be a man and suck that gas straight outta the system :P
https://www.sau.com.au/forums/topic/393228-ac-removal/#findComment-6255363
It is unroadworthy as mentioned above due to needing A/C for front screen demister. So keep that in mind. Other then that just vent it outside or in garage with door open. Usual OH&S shit. Don't inhale or get your eyes blasted.
https://www.sau.com.au/forums/topic/393228-ac-removal/#findComment-6255728
isn't it only a legality to have a heater?
i'm not removing the whole system cos i want to be able to put it back one day.
It isn't a roadworthy issue as only the heater needs to work to demist the windscreen, thus so many older cars never being fitted with A/C in the first place. If the demister doesn't work without the A/C in a car that had one, then it would be a problem....
https://www.sau.com.au/forums/topic/393228-ac-removal/#findComment-6256140
I had a quick look on Vicroads site and Found:
"Where optional and non essential equipment is fitted such as air conditioning, rear window demisters, etc, it is not necessary for it to work providing it does not adversely affect the safety of the vehicle or its compliance with mandatory Standards for Registration."
No mention of needing a demister or heater of any kind.
You even need Demisters for CAMS
Looks like myself and my foreman are wrong :ph34r: . He has had us checking all cars rear demisters and A/C for RWC. I Can look through the RWC regulation books at work to see what they say as they are way more detailed then Vicroads.
https://www.sau.com.au/forums/topic/393228-ac-removal/#findComment-6256272
its a $33,000 dollar fine or $165,000 if u have a buisness and arctic
services who control this travel forums and other sites looking for this type of
stuff.if its r134a gas u are realeasing takes 15years to realease from the
atmosphere if its an older system and takes r12 (pre 1993) the gas hangs around
for 100 years which is why they no longer use it,also if it is a r12 system u
will not be able to refit it later down the track u will have to have it retro
fitted.if u get sumone out just to recover the gas theres a good chance they
wont charge u for it cause they will get $3-$5 dollars per kg they recover.the oil in the system is hygroscopic and will give u freeze burns (frost bite)if it contacts ur skin as it absorbs heat if its a mineral oil.just a heads up :thumbsup:
https://www.sau.com.au/forums/topic/393228-ac-removal/#findComment-6256344
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
