Hi, i am selling my 89 Mazda 929 HC Luce.
Mazda 929 1989 HC Sedan
White in colour
Tinted windows
Sun roof
A/C
Alarm/Imobiliser
Mod plated
Engine
- 1jzgte
- T04z surge ported with gold bullet nut
- Steam pipe manifold
- TRUST external wastegate
- Sard injectors
- Sard fuel reg
- JUN adjustable cam gears
- Gates racing timing belt
- Custom stainless cooler pipes
- Trust BOV
- Custom stainless catch can
- Trust oil cooler and filter relocation
- Brand new coil plugs
- Speed flow lines
- Custom stainless power steering resevoir
- Turbo back 3.5" stainless exhaust with 2 stainless mufflers, 5" tip
- Plumb back wastegate pipe with removeable section (for screamer pipe)
- Plumb back catch can and BOV
- Intank pump
ECU
- Haltech PS2000
- Racepak dash with RPM, road speed, water temp, oil temp, auto temp, oil pressure, odometer, shift lights, warning lights, ect.
Gearbox
- Ford C4 3 speed auto
- 4,500 convertor
- Extended sump
- Transbrake
- Large PWR oil cooler
- Speed flow lines
- B&M Pro Ratchet shifter with transbrake button
- STRANGE tailshaft yoke
- Custom 1 piece tail shaft with tail shaft loop
Diff
- RX7 LSD diff centre
Suspension
- D4 coilovers all round
with adjustable camber tops in front
Brakes
- FD RX7 front callipers
- EBC front pads
- Bendix rear pads
- Slotted rotors all round
- Front stainless brake lines
Wheels
- Brand new XXR526
- Front 18x9+25
- Tyres 225/45r18 Kumhos
- Rears 18x10.5+20
- Tyres 235/45r18 Kumhos
Interior
- Standard seats ect
- Sunroof
- B&M Pro Ratchet Shifter
- CD player
- Front Kenwood splits
- Rear pioneer 6" speakers
- Battery in relocated to the boot
The body of the car is in good conditon considering its age, has a few small dents but nothing major.
I have personally changed all the fluids in this car within the last 6 months, oil and filter every 5000, auto, brake fluid, diff fluid and coolant have all been replaced with quality fluids.
Recently replaced water pump and spark plugs also.
Makes 380hp at the wheels through the auto.
I have run the car at willowbank and it has run 11.8 at 118mph.
Great cruiser/performance car, always turns heads
Will have to put pictures up later as it won't let me now or email me at [email protected] and i can send you some.
May consider a swap??
$14,000
Grant - 0466 365 305
https://www.sau.com.au/forums/topic/393229-1989-mazda-929-hc-luce/
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
    • Oh, I forgot to mention this before.  It is accepted that your taking on risk buy turning up the power on a 30 year old stock motor. You can lower the risk with the ECU engine protection, but this is more money on sensors. CAN wideband, oil temp, oil pressure, coolant pressure, fuel pressure, air temp, etc. It adds up quick.  I am a huge fan of running all of the engine protection the ECU offers. You'll have to decide for yourself how you want the engine protection setup and what you think is worth monitoring.
