URGENT SALE!
Car is registered however its currently defected (sticker expires march 14th) Car to be sold AS IS! I have pre-approval permits, I just need them signed off (can supply relevant paperwork) I have simply ran out of time.
It is a 1996 Series II r33 Skyline with an R34 GTR Front end conversion.
Details as follows
***Engine,Engine Bay & Driveline***
Engine bay has been full resprayed in electric orange (Ford xr5 orange)
hidden wiring of fuse boxes etc
Series II Rb25Det Engine
Rb25 gearbox
Exedy 5 puk clutch
Greddy FMIC
Kakimoto 3" Turbo back exhaust
K&N air filter
Whiteline rear adj camber bushes
tomei hicas lock
***Wheels,Brakes, suspension***
Car will come with stock r33 wheels
Greddy Spec R coilovers
Removed ABS
GTR rear strut brace
***Exterior***
r34gtr front end: genuine plastic front bar, fibreglass lip, fibreglass vented bonnet, URAS Conversion guards, r34gtr hinges, latches and bumper support, and r34 headlights with HIDs
Nismo front gtr indicators and nismo side indicators
Type m bodykit
Stealth wing
Ganador side mirrors
Carbon b pillars
Shaved boot lock
***Interior/Electronics***
Defi Boost gause
Red Bride Recliners
Nismo gear knob
Hidden fuse boxes (makes the interior so neat!)
Pioneer deck
alpine vpower 4 channel amp
alpine type-r splits
eclipse 10inch sub in custom boot install
Please email any enquiries to [email protected] and I will get back to you as soon as I can.
Accepting offers over $12,000. Happy to take seats out for less. Open to offers/swaps. Happy to ship interstate at buyers expense.
Pics can be viewed
http://perth.gumtree...QAdIdZ345055838
Edited by D K C
https://www.sau.com.au/forums/topic/393232-urgent-sale-r334r/
The add is targeted at the west Australian buyers as there isn't so many over here ( I think 2 now could be wrong ) however the other one definently isn't to the quality and is just gtt panels ( non gen at that )
As said happy to lower price with removal of few things. Car presents itself great in the flesh.
Also happy to accommodate all haters comments :)
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
