Hello everyone!
After i've read very much in this forum i decide to register me. It's my first post here, so i want to introduce myself. :-)
I'm from Switzerland and my english isn't the best, but i'm learning. I have a Skyline Gts-t 33 and a 200sx s13 which i've build for drifting. i bought the skyline with a big topmount GT3582 A/R 82 turbo with a screemer pipe on it. It's very funny to shock people with wheel spins on the first three gears ( sometimes as well on fourth) and the "shootgun-effect" ! :banana:
But for serious street an track purpouse it is much to laggy an to uncontrollably. Now, i will go with a GTX 3076 AR 82. Does someone know if the oil an water line connections are the same on GTX30 and GT35?
So enough stuff from me. I'm looking also for a GTX 3076 AR 0.82 with the T3 in, 5-bolt out turbine, low mount setup. I've found very much usefull informations on this forum. I know there is a bolt on setup from boostnimports, but what i read and personaly think, is the 6-bolt turbine housing (whats the correct name of it? T28?) to restrective for 280kw+.
It require a 10mm T3 spacer platte, longer bolts, new nuts and gaskets, a 4" suction pipe, oil and water lines and a 5-bolt dump pipe.
But there are still some questions left.
- I have search the hole internet for hours, but i haven't found a 5-bolt rb25 dump pipe. Does anyone know where i can get one? I¨ve seen solutions, who they cut the 6-bolt plate away from the dump pipe and welded a 5-bolt plate on. But in my eyes the problem of bad flow from the 6-bolt outlet isn't fixed, because the dump pipe itself is to small.
- Does maybe fit a SR20det or a Mitsubishi Evo outlett pipe? They flows well and it will be easier to weld the Rb25 straght to the end of the outlet pipe.
- Have the SR20det the same oil thread in the block as a Rb25. I've a well thermo-isolatet SR20 aftermarket oil and water line set here, so it would be nice when they fit? Or is it possible to use new OEM oil lines?
- I have another GTS-T 33 with a Apexi RHX6 Turbo kit here. Very, very nice to drive! It have mounted a Apexi 4" sudction pipe kit. Does anyone now where i can get it or another 4" suction pipe`?
Sorry for so many questions, but i'm very thankfull for every reply! :worship:
https://www.sau.com.au/forums/topic/393291-5-bolt-dump-pipe-rb25-and/
Im pretty confident you cant buy a bolt on dump pipe for the 3076/RB25 R33 combo.
It shouldnt be hard for someone to make something up for you to fit it. And as far as im aware most of the garret 5bolt internal gate housings are the same? So the flange wont be hard to get either.
It probly doesnt matter to you in Switzerland, but the Ford Falcon XR6 Turbo uses the same flange/gaskets. So Ford is an option. Thats where i got my gasket for my 3076 hehe.
yer all the small frame 5 bolt 3" outlets are the same. i got a flange and some pipe from a local shop fairly cheap and made up a dump with a mate, its fairly easy for anyone whos done exhaust work before. its for sale if anyone in perth wants one.
I will give you an update. There are three options:
-Housepowerinabox offers a bolt on GTX3076 T3, 5bolt kit for $2320. Include everything for fitting ( oil lines, spacer platte, bolts, nuts...)
And Compatible downpipe for $298
- ATPturbo.com offers the GTX3076 with two different ways for a internal wastgate.
- a small ford style outlet with a speziel V-band adapter flag with internial wasgate to bolt on.
http://www.atpturbo.com/root/releases/release103105.htm
-Or the big Cosworth Style 5-bolt housing with internial wastgate.
http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=tp&Product_Code=ATP-HSG-037&Category_Code=GTX
For both ATP posibilitys are spezial made downpipes necessary. But fabricate a downpipe with downpipe is easier.
The ATP variant with all necessary parts and housings will cost about $2300
What do you prefer?
    • Unless you have big cams, there is no reason for an RB to idle at any more than the stock 650. No, it is not 850, 950, or anything else. It is 650. In fact, it might even be 550. I just opened an arbitrary stock Neo file in Nistune, and this is what I see
    • I love the undertray, especially the flappy bit for easier access for serving I'm thinking of fabing up one at work for the MX5 while I still have access to the metal shop at work with a guillotine and press brake Whilst removing the plastic undertray on the MX5 isn't to hard, I love the idea of a 2 bolt flap as opposed to removing the whole thing
    • Great thank you for that. Yeah that is the bumper and spoiler it still has i just hadn't heard of it being referred to as a aero form bumper before. Really appreciate your help.
    • A little progress; I took the opportunity of an oil change to take a sample for oil analysis, will be interesting to see how it was treated for its first 125,000klm (I know how it has been treated since :rofl:) I went with 5w40 and will see what that does for oil pressure at higher revs. Also fitted the Z1 front undertray....a little more sturdy than the plastic factory one (although I suspect it won't stop a tree stump ) Nicest thing about it really is the 2 bolt "service panel"....a gift to the oil changer compared to removing 14 bolts holding the factory tray.
    • I think a scissor lift is better/faster in most cases, but I guess it does obstruct access to the centre of the car? BTW I weighed the quick jack. 3.5 tonne model is 50kg for each side. So yes, portable, but not with one finger
