Hi all,
Just picked up my v35 yesterday. I love it but this might sound silly, I cant get used to the speedo. anyone else have the same problem. The numbers and lines dont match up so i was going by the lines but felt I was going slower. Can someone explain to me what speed is what line on the speedo? - Sounds silly and I feel stupid asking. Please be kind.
https://www.sau.com.au/forums/topic/393321-v35-speedo/
If I understand what you're trying to convey and your cluster looks like this then:
Thickest lines are the 20Kph increments (20-40-60-80)
Mid Thick lines are the 10kph increments (10-30-50-70)
and the thin lines are the 2kph increments in between.
Edited by mosoto
https://www.sau.com.au/forums/topic/393321-v35-speedo/#findComment-6255999
The real issue is when the speedo goes past 180 and there are no more numbers..... but the best explanation for you is above and with a pic to :thumbsup:
hahaha nice, thats what a pivot speed meter is for and OP, is digital so easy to see what speed ur going ;)
https://www.sau.com.au/forums/topic/393321-v35-speedo/#findComment-6256252
post-92137-0-99384500-1330563148_thumb.jpgmy speedo looks like this. should have added a pic when i posted. Mine looks completely different to yours. My numbers dont line up with the lines. So i tried ignoring the numbers and go by the lines but it feels like im driving like a granny.post-92137-0-99384500-1330563148_thumb.jpg
https://www.sau.com.au/forums/topic/393321-v35-speedo/#findComment-6257206
Also what year?
Edited by Marshan
https://www.sau.com.au/forums/topic/393321-v35-speedo/#findComment-6257224
Looks like someone has replaced the outer ring with one from a US model.
The G37 speedo has eight larger lines like yours does whereas the cluster showing kms has nine larger lines.
Now, I wonder how many kms your car actually has on it.
https://www.sau.com.au/forums/topic/393321-v35-speedo/#findComment-6257380
LHD???
It's 2006. But they replaced that component because it wasn't displaying the fuel level properly. So it used to have the same as you. I don't know why they put this one in! How am I meant to kno wat speed I'm going???
I kno when we previously looked at the car it had done about 24000km.
Edited by 1stimport
https://www.sau.com.au/forums/topic/393321-v35-speedo/#findComment-6257381
What part of the cluster was replaced because that my friend is a return to dealer issue. There is definitely a mismatch of components rendering the display useless. In fact if inspected by plod they would sticker your car I'm sure.
I would be seeing about getting that fixed.
Edited by mosoto
https://www.sau.com.au/forums/topic/393321-v35-speedo/#findComment-6257491
That whole component was replaced because they couldn't fix the fuel gauge on the original one. I called the place where I got my car from and I'm going to take it to the mechanic that fitted it because i need him to check the muffler as well. Its making a noise sometimes when i turn corners or acclerate. So i will ask him to check calibration and the muffler. I love my new car but it's hard to drive it around when I'm not sure what speed I'm going lol.
Thanx everyone for your responses!
https://www.sau.com.au/forums/topic/393321-v35-speedo/#findComment-6258592
Looks like someone has replaced the outer ring with one from a CANADIAN model.
fixed.
USA in is imperial.
https://www.sau.com.au/forums/topic/393321-v35-speedo/#findComment-6259494
Which is why I said the outer ring and not the numbers.
The numbers are obviously from a metric version but the outer ring (with the lines) is from an imperial cluster as it doesn't have enough of the larger "main" lines, thus from the US model.
Thanks for fixing my post though Chris :P
https://www.sau.com.au/forums/topic/393321-v35-speedo/#findComment-6259546
  • 3 weeks later...
Thanx guys for all your replies took car to their mechanic and he agrees it doesn't make sense. So they are replacing it 2moro with a 'normal looking' speedo.
Apparently what happened was when they ordered it they asked for a compatible one and that's what was sent.
https://www.sau.com.au/forums/topic/393321-v35-speedo/#findComment-6283524
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
