Hey guys,
i think its my usual pre-track paranoia but i been hearing a sorta ticking noise from my engine and as far as i can tell it sounds like a noisy valve. it is nearly due for an oil change so im gunna do that probably tomorrow to let it run in before wakie.
just wondering if anyone knows any good mechanics that could have a listen and also hoist it up and check over the car, just because i may as well hehe.
https://www.sau.com.au/forums/topic/393347-any-really-good-newcastle-mechanics/
just called hunter thomas automotive (not sure if i spoke to paul, was an older sounding bloke) and booked in a rego check as its due.
think a rego check would fail if there is a ticking noise?? generally theyd only fail it for oil leaks and brakes and what not wouldnt they?
dad said its a valve hitting on something (cant remember what he said it was) and told me to ask you guys (will ask in proper section if no love here) if the lifters are adjustable on a RB25DET its a Neo s2 if that makes a difference.
1331531198[/url]' post='6271132']
Could have a big end rattle and should still passThey are checking the car is safe and as such a ticking noise shouldn't matterJust remember to put those nuts back on the top of the shocks if you haven't done them
Should be solid lifters aAnd not adjustable without a lot of work but I could be well wrong on that
hmm not to sure ay, might take it to my mechanic in wollongong. dads pretty cluey hes usually 90% right.
how did you know there were no nuts on the shocks?? i didnt even know they werent there till i just looked. where do i get a couple nuts for it???
ive never regod this car so not sure what needs to be done. hoping itll just pass lol.
hmmm that sucks. not to keen to pull stuff apart sigh lol. seals/gaskets cost to much!!
All RB's tick. i'm sure its normal
as long as you have good brake pads, tread on your tyres and working lights, you should be right for rego.
Ask Paul to have a listen, you don't want to drive to the gong if somethings going to go bang.
Now that I think about it could it be cause I've been using 95 petrol? Itsnot a pinging noise though it a tick. Just relised I've been putting that in probably around the time it started!
Not this if it does it all the time. from my limited understanded, you wont get denotation until under boost with 95.
You should start getting 98 though....remember your car was prob. tuned to 98 (if done in australia) or 100 in Japan.
