Hi All
Just when I started to think I was a festering wart in the world of Skylines, here is a forum dedicated to Naturally Aspirated Lines. Thanks to Demon Dave for the Intro Link.
Well back in Feb 04, I bought my dream a 1998 R34-GT N/A Skyline, obviously I wanted a turbo but got a fantastic Part-ex on my old Max Power Car, but couldn’t raise the extra cash at the time to go for GTS. Since owning it, It certainly quick enough, I’ve taken out many a car that’s tried for example BMW M3 (I started to pull away at 105 mph), Porsche Carrera S 2, Honda S2000 (on the Fly), Toyota Supra (all show no go) and many others. (Agreed they could have all been rubbish drivers).
Anyway, I'm now excited about the prospect of having an ultra fast N/A Skyline, because it's different and there is not that many out there, well in UK anyway.
So my quest is to start modifying it… but in stages, with each month’s pay packet.
I'm now looking towards my future projects in the form of a shopping list of what should be the next mod, in order to get the power up to Turbo Figures; 300bhp +
So far I’ve fitted the following.
Engine; Now maybe 230bhp??
* HKS Air Induction
* HKS Iridium Plugs
* Blitz Nur’ Spec R Cat back straight through System
(Originally made for the GTS, GTT but once I modified the Cat replacement it was fine.)
It has a 80mm Boar, and is outputting a deep throaty sound at low revs and then a screaming but sweet 105db at full power. Awesome :wassup:
Wheels & Suspension
* Antera 8x17 Alloys
* Rubber, Marshall 235/40 fronts & 265/35 Rear
* Lowered Springs
(I'm not sure of the exact drop as they where second hand but drops the ride hieght by about 2" maybe 3")
I felt the standard Nissan set up was unpredictable and almost dangerous at high speed, especially over undulating road surfaces. I also found that the back end would easily breakaway from you even in the dry.
The new combined wheel, tyre and suspension mods make a massive improvement in the handling, (THIS IS A MUST FOR ALL) I'm now much more confident when high speed cornering, in the dry you can feel the back wheels bite and dig in. Fantastic adition. :headspin:
NEXT Engine Modification Ideas
(Here’s where you guy's come in) has anyone any suggestions, experience, Performance gain figures or make and model recommendations for any of the following mods. or even any additional ideas I’ve missed out.
ECU
Remap?
Chipped?
Cool Air Compartment in engine bay for Air Intake
Vents in the Hood to let cold in and warm out.
High Lift Cams
High compression pistons
Tougher valve springs
Fatter head gasket to improve compression ratio?
NOS (anyone fitted one yet) is it a ‘do-it-yourself’ job or if I try will I blow myself to little pieces
Port & Polish
Exhaust Down Pipe
Exhaust Manifold
Super Charger?
Turbo?
Traction control diff or axel from a GTS or GTT ?
Front Splitter on bottom of the front bumper
Or Bomex Body Kit
Anyway that’s all I can think of for now but I’m sure you guys out there will have something to add. :cheers:
Hey there,
glad you found your way over here - this is the place for us N/A boys :D:cheers:
re: your exhaust - if it was designed for a turbo model you might be not getting the full benefit of it - indeed you could even lose some power. I'm running a kakimoto system (main bore is 70mm, tailpipe 110mm) and I definitely notice a power drop at lower revs (compared with stock) due to lower backpressure.
The pod could cost you some power in the summer (not that it ever gets that hot in Old Blighty :() but without an intercooler reducing intake temps, I'd recommend some kind of cold air partition. Or maybe even ditch the pod and got with an uprated panel filter and a modified airbox....
I agree they would have been rubbish drivers :P
I first thought of going the hardcore N/A route with my one...I was going to put the neo head on the RB30 bottom end and go from there with lots of bolt on goodies and port and polishing....then I looked at the cost and said **** that I'll turbo the engine and keep the high compression...well worth it bang for buck!
Dan
yea i was gona do all that, but i just sold the damn car and bort a turbo. The REAL thing!
I guess its hard to part with the car u got etc.
But if not, do an engine swap :)
With the money you will spend on doing all that u could put in a turbo engine with more power ild say.
But unless u wana be all origanal and go for N/A power, do it!
well uve certainly got a nice list there. Go with what ur heart desires, ECU is definately a must, make sure u do things that give u a really good power band from down low all the way to redline. Thought about higher compression kits for higher revving ? can u imagine the power output say at 9000 rpm with forgies and shit :) endless possibilities man!
Clint
I presume forgies, are Pistons?
Thanks for that link.... Obviously these guys know what they are doing and just look at all those Skylines in the back ground on the outside pic... Luuverly
I cant suss out whats going on with the mod... almost looks like a different engine once mod is done.. but presume its a different head... obviously different manifold and ECU ..... shame I cant read Japanese... I will have to get the page translated ..if I remember correct I think Yahoo translates?
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
