FOR SALE
A SET OF LIKE NEW GANADOR MIRRORS $450.00
A SET OF GTR TURBOS(minimum shaft play)& DUMPS $300.00
FUEL RAIL $50.00
WALHBRO FUEL PUMP GS342 BRAND NEW IN BOX $120.00
GTR STANDARD CAM GEARS $100.00
TURBO TIMER $50.00
R32 GTR FRONT GRILL(like new in silver) $150.00
R32 GTR REAR SPOILER(silver) $250.00
LIKE NEW SET OF RIMS AND TYRES 18/9.5/265 ALLROUND (see pictures in gallery) $950.00 or swap for jap style rims
MAKE ME AN OFFER.....pictures can be emailed/sms
https://www.sau.com.au/forums/topic/393360-mirrorsgtr-turbos-and-dumps/
Located in Camden , NSW
Picture has been emailed.
Make me an offer on all parts , all must go to finance a engine build.
Others parts available soon.
Striping RB26 , let me know what you need.
In the Stagea forum there is a guy in the UK after, maybe, Rb26 loom. Check him out.
All reduced:
Mirrors now $400.
Turbos with very minimum shaft play now $250 with dumps
Fuel rail $50
Front grill SOLD
Rear spoiler SOLD
Turbo Timer $30
Konig rims with like new tyres 18/35/265 now $900
Rb26tt motor standard , without computer & turbos , low compression. $2500
All must go
Call/SMS 0422370051
post-83894-0-01030500-1331286888_thumb.jpegpost-83894-0-16650400-1331286768_thumb.jpg
All reduced:
Mirrors NOW $400
Turbos with very minimum shaft play NOW $250 with dumps
Fuel rail $50
Front grill SOLD
Rear spoiler SOLD
Turbo Timer $30.
Konig rims with like new tyres 18/35/265 NOW $900.
Rb26tt motor standard , without computer & turbos , low compression. $2500 NOW $2000.
All must go
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
