i have one of my toys up forsale its a 1997 genuine180SX type X , i am the second owner after it being imported , car has 155xxxkms , REG TILL JULY.
Basic Modifications include:
-Black Top SR20DET (motor has had previous rebuild tostandard specs)
-5spd manual (S14 200sx gearbox)
-Aftermarket exedy clutch
-3" Turbo Back , custom dump pipe
- Disco potato with 14psi actuator (Jap warehouse setup)
-Front mount intercooler
-Custom intake pipe to turbo + pod filter
-Fully adjustable BC coil overs: front 10kg / 8kg rear
-Drift pineapples
-Adjustable camber arms
-Drift BOV
-Aftermarket Fuel pump
Interior/Misc :
-6x9 speakers
-12" sub in boot
- White LED headlights
-Viper alarm system
-strut brace
Wheels
-Driftek 18x7 fronts, 18x9.5 rear
Car has had a recent major service, brake pads fitted andwheel alignment done. I also have a few standard parts in which I will give tothe new owner of the vehicle.
there is probably a few things i have missed all in all thecar is in great condition and has no rips in the seats or cigarette burns ,fuel consumption is great on this car also , car is running a safe 12psi and ismaking around the 160rwkw mark , was tuned by previous owner.
Reason for sale is that im building a new house with mypartner and need funds to help with deposit.
10.000 ONO (NO RWC)
PRICE IS NEGOTIABLE
Regretful sale
Please contact Nick on 0421-238-541
NO TIME WASTERS OR TEST PILOTS PLEASE!
https://www.sau.com.au/forums/topic/393362-1997-nissan-180sx-type-x/
sorry for the late reply mate
im located in the western suburbs of melbourne , i was told by a previous owner that motor was rebuilt , not to sure on exact kms etc
the car has ticked the 150,000 mark so as for service , did oil , plugs , brakes, wheel alignment . timing belt wasnt changed as it would of been done previously with old owner
any other questions you can contact on my mobile bud
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
