  • Replies 123
for the 10,000th time Mafia I run a atmo bov and have no problems and run 300rwkw...
so go eat dick...
Help the OP diagnose the problem if your so good, maybe, just maybe its something other than one of your pet hates....
so go eat dick...
When I bought my car it also had an atmo bov and never stalled once on me, never ran boggy, never had issues.
so go eat dick...
lol ive had turbo cars n for 10yrs all had u know those wanker twirly things that get women to get naked on side of the rd lol and not once have a ihad any problems with bov bein atmo lol but im just a loser who knows nothing cos im no a "TUNA"
and yes im calling u a fish cos its just an insult to ppl who tune cars to call u a tuner
lol mr mafia i suggest u go chow down on some cock buddy lol
You can bandwagon all you like, but I can see the retardness all the time when I have the wideband in. Whether you think the car is running right or not.
But if you guys want to think or continue to think that adding an air leak to a AFMetered system is a wise idea, then complain about any kind of stalling, good for you. Just shows you do not understand at all. Just want noise.
Maybe buy a MAP sensored ECU so you can blow off your load all you want.
It all physics, and in plain black and white - ATMO BOV + AFM = Wrong, never meant to happen.
There is nothing to tune around, other than "fudging a few figures". But it can never be fixed. - And, I hope you do realize that a BOV that doesn't leak, is one that is welded shut, or recirculating back?
The second the BOV opens to make the big "whhhooosshh" its leaking? Can you not see that? How can that be not obvious?????
Also, when your BOV is tight, its not doing anything, other than creating reversion... you know... tututututut.......
All these problems... for a noise.... amazing
Yes I realise when its open the system is leaking, yes yes...
Im not into the sound, its just the fact that I dont want a crap rubber hose going from side of the engine bay to the other (forward facing plenum)
and I cant yet justify getting a nice metal pipe fab'ed up just yet... yet
seriously though cars can run fine with an atmo, I have hardly any knock, Im not too worried about reversion as its only on low pressures this happens with mine, otherwise its a straight release no tut sound.
Just everytime someone says atmo you immediately jump down their neck about it, its definitely your 'pet hate', get over it...
you have good knowledge, why not help out the OP and then 'IF' everything points to the problem being the atmo sure suggest they remove it...
verbally abusing people for it aint the way too go...
I have already helped the OP by stating that the SARD is junk. He even answered his own question.
I've seen so many of them exhibit this exact symptoms, and make the car useless to tune.
Hence now, if I pop the bonnet and see a sard or malpassi, I tell them not to come back until I see a nismo or factory one attached.
Edited by The Mafia
You've made 2 changes, and now the engine doesn't run right. Well then, the obvious thing to do is go back to the point where the engine ran without any problems, and change just one. If the engine still runs fine, then it has to be the second change that is causing the current problem. Otherwise its the first change that is causing the current problem.
It's not rocket science.
Mr Mafia you seem adament that an atmo BOV on a GTR will 100%, without doubt, put ya house on it cause a rich condition on decel because you are so Knowledgable and a specialist "tuner" but do even know that a GTR shuts the injectors OFF on decel? So your entire thesis/theory on OEM GTR BOVs is how does one say ..... Horse shit!!!!! Hmmmmmm....... And as for SARD fpr's the only times ive ever seen them give trouble is when 1 has been fitted incorrectly or was 1 of the chinese copies that have diaphram issues.... What is your background? ie: where did you learn to tune? Do you have a workshop or do you work as a tuner for a shop? Now to the orig poster i had this excact same issue with my R33 GTR and it turned out to be 1 of the AFMs was shagged. Replaced them both and problem went away. If you can borrow a pair of known good AFMs to try do it asap and save your hair. PS make sure you have the fuel lines going into the correct ports of the fpr, they cannot go either way. Erratic fuel pressure is a major cause of concern imo. Cheers. N if i was you id just ignore Mafia seems like he got a laptop for xmas and now with a few cables he's a "tuner" ...I dont know why he gets so jacked up over something so trivial but im guessing it was because he knew something that nobody else did!!!!
i been thinkin fuel reg since it started thing is i thought id rule everything out b4 i had to start spending money.
i dont have the standard reg or rail anymore so cant really go back
mafia says fuel reg so im gonna try a mates one tonight see how it goes n to make him happy im gonna take the bov off.He knows his shit but just the way he talks to ppl i dunno how he has any customers.
also thanks to those who dont talk to ppl like theyre a peice of shit
hey man thanks heaps ay ill try get a pair of good afms to try man and yeah i appreciate ur not blowing up at me lol
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
