P.S. I'm a tuner.
And I refuse to properly help someone complaining about a stall problem when they have a ATMO bov. Its an airleak. Just like pulling a hose off and leaving it off. Except it only leaks air when you back off the throttle.
I just love pointing it out to people who have no clue of this air measurement system and post countless threads on SAU.
were you beaten as a child? severely?
So, your a tuner. BIG DEAL. Plenty of them on here. Your the only one who continually carries on like a skirt.
Wake up to yourself champ
  • Replies 123
Trav u should drain all the fuel in ur tank, top it up with fresh fuel.
U can come grab my afm's today if u want, and another ecu to try,
I'll try come up on the weekend but flat out at the moment with the new shop
Mate im sure you've got the same issue i just had, my car has a nismo fpr and went down that incease-decrease pressure routine. And same as you the last things i touched before i had the problem were changed turbos and new cambelt so FM "shouldn't have been an issue. But soon as i tried some other AFMs my car instantly sounded,drove went better than ever! Even uses about 10% less fuel. Try it dude. As for Blue Fin aka Mafia with the "REAL LIFE" expierence i can assure you ive already forgotten more than your ever likely to learn... Just stating the REAL LIFE facts.
also i replaced my idle control valve completely so i wouldn't think its going to be your issue. Take DVS up n his offer ASAP :cheers:
yeah just went n got a nistune off him and some afms ay will post my results soon
Even though I've got support, you're just a wanker.
You keep blowing off your cock around the place.
ffs mate seriously either help us or f*** off we all sick of ur attitude mate. seriously if u got nothin constructive to add other than u love playing with ur tiny cock just dont post anything
thankyou!
thankyou!
My cock is huge, I don't need a bov to make up for it.
well the funny part is that any guy thhat walks around tellin ppl his dick is huge need to compensate mate so as i said ya wanna help great if not cya later ay
Actually, I was just correcting the tool. He incorrectly stated that I had a tiny cock, most likely based in the assumption that most blokes manhoods are around the same size as his.
I'm afraid to say, they are not.
Hence he requires a loud BOV to extend his penis size. Makes him feel better obviously.
will u read what ur sayin mate.ur cock it the biggest in the world lol grow up child oh n ur just cut cos ur pickin on ppl who hhave bov's lol its cos theirs cars are better than urs so take it home put ur tiny little wang back in ur pants n stop pullin over urself for 5 seconds ok ur wrong bout the bov just admit it fool now like i stated b4 if u have constructive advice great if not just f**k right off
today i removed the sard fpr and borrowed a wait for it lol malpassi off my mates car knowing it works.So i set base pressure at 45psi with out vacume.Attached vacume line and it the dropped to about 30psi.b4 i did this i did remove my blow off valve.As i rev'd the car i watched the pressure gauge and come to the conclusion that the sard reg = stuffed lol
Hey,
Assuming your new FPR is working properly, sounds like your problem is too much fuel because of two things:
Atmo BOV == too much fuel when it opens. This is what happens on an air-metered car when the air is dumped.
Fuel pressure without vacuum should be 43psi for an R32 GTR (not 45) per p. EN-25 in the service manual.
With vacuum it should be about 36psi at idle, but the BOV change may affect that.
Try decreasing the base rail pressure to 43psi.
Cheers,
SW
Hey,
Cheers,
SW
ok thanks mate
Sorry mate but that sensor is only a "narrow" one.
It can only measure fuel when you are cruising. Once you start pumping the throttle it is ignored and the maps that Nissan wrote for the ECU are injecting the fuel.
Its called "closed loop" and "open loop" :down::sick::wacko:pinch.gif:domokun:
Once again the evidence is in the writing! Are you serious when you say this? I find it almost laughable that a well known, relatively expierenced "tooooner" has NO IDEA what closed loop and open loop lambda control is!! :domokun: Wouldnt say im surprised but from someone who shoots off so many bullets at others id have thought you would atleast drag out your reference manuals that you have learnt from, ie: the ZOOM,HPi,Fast 4 magazines. If anyone wants to know what this really means and does just ask here and ill give you the correct answer..
Travis what ecu are u usung? OEM?
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
