In what way?
They vent air and it's driveability - nothing you can test on a dyno really.
Well I was running twin blitz vented. then forged my engine and had lots of stalling issues, turn out one of my blitz was jammed so I took it off and put a OEM instead. so I'm running both. However, my tuner didn't told me anything about beeing more eaiser to tune or not.
My car can still stall but maybe 1 times out of 10 during braking instead of 8 times out of 10.
So I mean, if it's possible to tune the car vented or not with the same result. and no one can prove that recirculate will yeild a 200rpm increase in response and I dont know... 10whp more. And your car doesnt stall on every corner. Why so much peoples sh*t bricks on ppl running vented !? I can't recall anyone showing a bck to back dyno proving vented is worse.
  • Replies 123
had the same problem in my old supra. turns out it was my ecu playing up. wasnt sendin the correct voltage to my injectors and therefore werent pumping enough fuel and would cause it to stall at the lights and stuff.
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....馃ぃ) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
    • R33 with RB26 seems to go off of learned voltage for idle. Seemed like whatever the baseline voltage was once ECU first gains power will be the idle voltage. With ignition on unplug/replugging the TPS would relearn the idle TPS voltage.
    • Have you confirmed the 2 pin coolant temp sensor on the motor is working properly? I've had a very similar issue when I forgot to plug mine back in many years ago.
    • Ok interesting i guess ill wait till using a manual gauge before making assumptions.
