Hey guys just chasing ;
R33 gtst front lip
R33 gtst drift style wing
R33 gtst rb25det rocker covers (cheap price)
Aftermarket toe control arms (cheap price)
Aftermarket rear camber arms (cheap price)
15mm 5 stud spacers to suit r33 gtst s2
If your selling any of these just pm me ,
R33 gtst front lip
hey there mate , how are ya ?
sure am able to help you out with the rear lower toe arms , rear upper camber arms and 15mm 5 stud spacers
1 ) 1 x PAIR , D.R.I , BRAND NEW , fully adjustable & strengthened rear camber arms pillow ball for s13 , 180sx , r32 , a31 & S14 , S15 200SX , R33 , R34 SKYLINES etc = $180 pair
2 ) 1x , D.R.I PAIR OF REAR TOE CONTROL ARMS , PILLOW BALL/ROSE JOINT , FULLY ADJUSTABLE & STRENGTHENED , ANODISED BLUE IN COLOUR , BRAND NEW TO SUIT S13/180sx , S14 , S15 , & ETC = $200 PAIR
3 ) 1 x , BRAND NEW , PAIR , D.R.I , 15mm , 5 STUD x 114.3 PCD FOR = $165 PAIR
4) 1 x , BRAND NEW , R33 SKYLINE GTS , SERIES 2 , FIBREGLASS , SIGNAL STYLE , DRIFT WING / LIP FOR = $315 EACH .
Edited by DRIFT RACING INDUSTRIES
Ok guys got half of the shit here now ( sau is awesome ) just thought i might add that i am in need of a deep dish steering wheel and an accompanying boss kit if any one is selling please hit me up ASAP! Suede prefferably, sell it cheap cause im ctingy sunt! :D
i've these with reasonable prices
1)Front tension rod kits $ 130/=(new)
2)Front camber arms $ 250/=(new)
3)Rear upper camber arms $ 120/=(new)
4)Rear lower camber arms $ 250/=(new)
Interested? PM me. Will post Australia wide @ buyer's expenses.
PRICES are fixed.
https://www.facebook...29504222&type=3
  • 1 month later...
    • Sounds good. Provided the panel is flat/level I'd be happy to start the painting process.  While you are learning, for sure you could do this. Its only paint, you can always sand it all back and start again. Its only your time and money on materials, but while you're learning, really its time and money spent on your education.  Once you know how to do this bodywork and painting, you won't want to waste your time and money on frivolous activities lol.
    • Yep I will use a guide coat after putting filler, I will do it on the whole panel as I'm a beginner so chances I've made quite a few errors. In that photo, I think that was a low spot, I just for example said to pretend it's flat but I will put filler + guide coat after to assess where I'm at. Yep with that picture, the panel is wet as it rained when I took the photo. But all those scratches are completely smooth, I went over it with 240 grit and can't feel it, even with my nail digging into it. I was legit thinking to buy a 2k can and spray primer to see how it turns out but then thought to myself it's going to be a mess doing it haha. Good mention there. Thanks for all that info I think I know what to do next.
    • Prior to laying down the primer, you need to make sure the surface is completely level. For example, based on this picture, I strongly suspect that the areas marked in blue are higher then the area marked in green.  If you spray primer over this entire area, then paint and clear it, the finished result will 100% show the low area. It will stick out like dogs balls. Unfortunately the paint won't magically level out the low areas as you lay it down.  Without seeing it in person, I expect that the green area will need to be filled, then use a guide coat and check that the entire repair area is level with a large sanding block.  With this picture, are you saying that even though you can see the scratches, the panel is in fact completely smooth and flat? If this is the case sure you could prep and paint it as it is.     The picture with the paint you described as blistering, it's hard for me to comment on from the photo alone. It looks like the panel is wet? Dunno, looks strange. Does the panel feel as smooth as glass when you run your hand over it? **** Going back to your question again, generally you would only sand the primer if you made a mistake while laying down the primer.  If the panel is prepped properly and you lay the primer down properly, you should not need to sand the primer.  This wouldn't work - Don't prep the panel. Spray primer and see how it turns out. Sand the areas where the issues appear. Spray more primer and see how it turns out. Sand the areas....... Yeah you'd go round and round in circles getting no where.
    • That's sick, thanks for that, mine has much the same mods on a 400R. I just don't have the heat exchanger yet.   Might be worth a trip down the M1 to Syndey for a tune.
    • Mate , this is the current mods list Current Mods list (Installed) RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler AMS Alpha Performance Full Race Down Pipes ECUTEK tune form TuneHouse in Sydney .(Just over 2k) The car came with HKS - Power Editor but I had it removed for the full tune. I would say if you are using the car for street diving a proper tune would be better.
