...ahh, on a Sunday? Depending on my alcohol level I suppose.
1. Shell
2. Kat
3. Cejay
4. DIY Mik
5. Sinista32
6. Zombie_drifter
7. Randon_I_Am
8. Kasko
9. Anfanee
10. sweefu
11. Sir son of rajab Van Von Vader'ham
12. Scar
13. 5hiv
14. STAR33 (tentative)
  • Replies 146
I'll come to this, haven't been to an SAU event in a while!
1. Shell
2. Kat
3. Cejay
4. DIY Mik
5. Sinista32
6. Zombie_drifter
7. Randon_I_Am
8. Kasko
9. Anfanee
10. sweefu
12. Scar
13. 5hiv
15. ZCR
Pleb 1. Shell
Pleb 2. Kat
Pleb 3. Cejay
Pleb 4. DIY Mik
Pleb 5. Sinista32
Pleb 6. Zombie_drifter
Pleb 7. Randon_I_Am
Pleb 8. Kasko
Pleb 9. Anfanee
Pleb 10. sweefu
Pleb 11. Scar
Pleb 12. 5hiv
Pleb 13. STAR33 (tentative)
Pleb 14. ZCR
Better.
not boss - Tyrant.
And if my plebs are not fully ready for my arrival... well, lets just say i'll make this guy look like a comedian.
Iseewhutyoudidthere!
Since I cant make the SAU Track day I'll come to this...In my banged up stock supra lol
just so your all aware the venue has changed due to all the rain
it is now at thoroughbred park mitchell, entrance of Randwick road. Marshalls will be there to point everyone to the right place. start is same time as they want all cars parked by 9.30ish
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
    • The ones in brackets are the first stages of tightening. I usually aim for the middle of the range. They give a range because it's actually not that critical to hit exactly the right bolt tension. Enough is enough, and too much is too much, and the range given is inside that range. Half of the bolts in the suspension are problematic for putting a torque wrench on anyway, so just get done up to mechanic tight  and spanner checked a week later.
