Hi guys.
Im selling my V35 skyline wheels, including Austyres tyres(215/45). All of those 4 tyres only have done about 500kms.
It was on my maxima A32 before. Sold my car, and not needing it anymore.
5x114.5 PCD
17 x 7.5 + 45 Offset (not sure if this correct, got it from net).
post-92145-0-74226600-1330577323_thumb.jpgpost-92145-0-56058700-1330577370_thumb.jpgpost-92145-0-88743900-1330577413_thumb.jpgpost-92145-0-43321200-1330577432_thumb.jpg
Price: $450 ono.
Just text me: 0431893864
https://www.sau.com.au/forums/topic/393427-wtsv35-wheelstyres/
Selling my Alpine (CDE-104BTi) as well. All working perfectly,included wiring hardness for nissan. The wire that connectd to iphone@ipod is not original.
More in depth info:
General Features:
Built-in Parrot Bluetooth Module
Front USB Connection
Full Speed Connection
Front Aux Input
Quick Search
SWRC Ready
Full speed AUX input
Rotary Encoder
Included BT Microphone
Display
1 Line LCD Display
White pixels
Bluetooth
Built-in Parrot BT Module
BT Version 2.0
Updatable for Future phone models
Outputs
Amp: 4 x 50W Max
2 PreOut (2v)
Power Antenna
Remote on Signal
Audio
MP3/WMA Playback
AAC Playback
HPF
Treble Center Freq. Con.
Bass Center Freq. Con.
Subwoofer Level Control
Price - $200 ono
Edited by ikhwan7
  • 1 month later...
Price drop to $400
And im also selling:
1) Hks muffler. Im not sure what Hks is that because it came with the car (R33). It have inlet of 3" then 3.5" pipe to muffler. The tip i reckon its 4.5". Price : $100
2) R33 rear strut brace. Price : $80
Edited by ikhwan7
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
