Ok guys need to go a different plenum set up to my current one, thinking of getting a greedy copy plenum but they don't have internal trumpets so the question is are they really needed on an rb25det? My mate said cylinder 6 leans out & doesn't get enough air to it if there arent trumpets is this correct?
Also what's your thoughts on the greedy copy plenums? Anyone had any dramas with them? & do they suit top or side feed injectors or both????
Cheers
Cheers
Might want to take advice from a better mate if hes saying that...... lean means to much air... not to little
I have a Greddy copy with no problems
I have a Greddy copy (of course there are a number of different manufacturers of these) on my RB30/25 going well so far. I am using the stock fuel rail and fpr and also stock throttlebody (needs an adapter plate) but it will also accept a top feed rail if you want. The only problem was that it didn't leave room for my clutch m/c so I had to buy an R33 one - problem solved. Also had to move my battery and washer bottle (minor issues). If I had lots of money I would have put an RB26 head on my RB30.
Trumpets have nothing to do with evenness of distribution between cylinders. Trumpets only serve one purpose, and that is to increase the flow into each runner - or more to the point, to decrease the pressure drop associated with the inlet transition to the runner. But even that is not entirely true. Because whilst it is true that (in a large enough plenum) a bellmouth trumpet that stands up from the floor** of the plenum will flow more than just a hole in the floor of the plenum, that does not mean that a bellmouth trumpet is in fact the best inlet to the runner. In fact, the best inlet to the runner is a rolled mouth trumpet that rolls back onto the floor of the plenum. ie, not really any extra length - maybe 10mm from the floor to the top of the rolled mouth. That is all that is necessary, and has been demonstrated with proper testwork to provide the highest possible flow into a manifold runner. However, if you do go to the effort to make a plenum that includes such rolled mouth inlets, then the plenum needs to be wide*** enough that there is room for the flow to enter the trumpet mouth as symmetrically as possible - ie, all around. **floor being the side wall in the case of a typical Greddy style front facing plenum on an RB engine. ***wide meaning deep in the case of a typical Greddy style front facing plenum on an RB engine.
I'm not gonna say I stand buy all of the Greddy copys, there are some duds out there, but genuine Greddy's I would 100% trust and a good quality copy as well. Mine was from Autobarn I think (Got it in a trade with someone) and all the surfaces looked pretty nice, as oposed to some which are uneven or weak
since when did autobarn sold fake greddy plenums? lol
they use to be trust/greddy dealers so it might eb real?
for a while.....
And I can say its definatly not real, Shiny finish like the copy's. Not rough grey finish like the real ones
That's because it's Autobahn88 not Autobarn. Autobarn is the franchise retailer, Autobahn88 is the performance store that sells the copy Greddy plenums thumbsup.gif
On topic, my mate uses an Autobahn88 Greddy copy on his 25. Was decent quality, everything fitted together fine and the build quality was decent enough. For 400-500 odd bucks, can't go wrong.
Autobahn888 (or 88 I can't remember.. 8 is a lucky number to asian countries) tend to copy (and do a shitty job) of every Jap aftermarket company, HKS dumps etc
i'm sure if you buy a copy, spend some time with a hand grinder cleaning it up and get it flow tested, it will work out cheaper and should flow just as good as the greddys. afterall, they are a copy of it.
the bloke who sells the mild steel top mount manifolds from NZ has half the plenums, you just add your own velocity stacks & flange and TB adapter, and your off, maybe something worth looking into if you're after something low budget yet decent??
No i meant autobarn the franchise...... They always have on the shelf where i live
Yeah the autobarn near me had them on the shelf but now they don't if u ask them they will order them in but to be honest
I don't like dealing with them but 999 automotive (triplenine)
Should have them or no where to get them .
They also go under the name of kls performance and power spirit .
Also eBay seller n power maybe able to get them I personally have bout a few things of n power and never had any dramas
I got mine from Vulture Motorsport. Very happy. Came with everything needed to bolt on
+1
Definitely. Quality was good too. No sharp or rough edges, nice thick walls, and great fit. Plus as stated above, every hose, nut, bolt, and nipple was supplied. I even rate their throttle body highly :D
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
