Pioneer DEX-P99RS which gives me ipod/iphone connectivity + I have a 160gig hard drive connected to it for my music library. Very rarely use the CD :) but there are plenty of ipod control head units on the market, just depends on your budget.
The factory Radio & AC controls are integrated on the one PCB so to go aftermarket you will need to mod the fascia and find a separate A/C control module like the one below:
Or buy the double din unit with controls like Howa mentioned:
eg: http://www.mynismo.c...oducts/?id=4343
Edited by mosoto
https://www.sau.com.au/forums/topic/393494-v35-stereo/#findComment-6260466
I'm looking to install JDM dashkit in mine right now. Any one know if the premium Bose came with an amp? I hear the USDM's have the amp located in the trunk next to the spare tire.
Also what type of wire harness do i need?
https://www.sau.com.au/forums/topic/393494-v35-stereo/#findComment-6261898
I'm doing the exact thing right now.
Ordered the JDM dash kit from japanparts. Metra buttons do look a bit tacky in real life so stick with JDM.
But basically you would need to also replace the AC controls. You can find them together with the facia, AC controls, single/double DIN brackets and tray.
Also get a harness for the wiring to save some headache, hope that helps
Hi everyone,
Wanting to know what I should replace the current 'face' for the stereo. I miss having the ability to play my iPod and listen to the radio. What does everyone else have?
https://www.sau.com.au/forums/topic/393494-v35-stereo/#findComment-6261904
Bose systems have an Amp in the boot, non-Bose do not, this applies to the G35 (US) and the V35.
You will need an adaptor to connect your aftermarket head unit to the Bose system.. Chris Rogers should be able to help you out with that.
If you just want radio and iPod, you can get the band expander to make the radio work here, and an iPod I/F for the factory unit. Would be cheaper than the double din facia, harness adaptor and aftermarket head unit.
Alternativly you could get a head unit from a G35, radio will work here and it gives you MP3/WMA CD playback ability. Doesn't help with your iPod though..
https://www.sau.com.au/forums/topic/393494-v35-stereo/#findComment-6261962
Oh sweet i think i need something like this:
http://www.ebay.com/itm/2003-2007-Infiniti-G35-Bose-Replace-Radio-Wire-Harness-/140494923285?pt=Car_Audio_Video&hash=item20b6266615&vxp=mtr#ht_1243wt_1163
To retain the use of the amp. Also any recommendations for the HU (not sure what power output i need).
https://www.sau.com.au/forums/topic/393494-v35-stereo/#findComment-6262068
Ok guys so i did a little research to save yourself headache with wiring (plug and play attempt).
With the Bose sound system in order to retain the amp you have to use the NSA-04. If you have a factory navigation system and you wish to retain that then go for the NSA-05 interface.
For none Bose systems use the NSA-03.
NSA-04 link: http://www.beatsonic...iti/nsa-04.html
NSA-05 link: http://www.beatsonic...iti/nsa-05.html
Like Greg mentioned speak to Chris Rogers and he should be able to hook you up.
I got my headunit yesterday (Kenwood KDC-U549BT) and realized that without the interface i will lose the amp along with the 2 speaks in my back seat down.gif
So far this is the only solution i know on how to retain the factory amp and speakers.
Parts so far (don't know if i may need anything else or if i'm ready for the conversion):
JDM Dash kit and A/C controls with tray
Head unit (possibly harness if needed)
Beat Sonic NSA interface
Any suggestions are welcome.
Note* These only apply if you have an amp setup so it's not for everyone
Edited by Marshan
https://www.sau.com.au/forums/topic/393494-v35-stereo/#findComment-6263274
  • 2 years later...
Pioneer DEX-P99RS which gives me ipod/iphone connectivity + I have a 160gig hard drive connected to it for my music library. Very rarely use the CD smile.gif but there are plenty of ipod control head units on the market, just depends on your budget.
Thanks for this info mate. Any chance these are still available? I'm only after the AC Control PCB like in the picture.
https://www.sau.com.au/forums/topic/393494-v35-stereo/#findComment-7285536
Onlt thing I could find: http://www.mp3car.com/mp3car-infill-g4-double-din-car-computer/99741-mp3car-infill-g4-install-in-a-2003-infiniti-g35.html
or Riverside Infinity. Also try the G35 Driver forums, you might get lucky.
https://www.sau.com.au/forums/topic/393494-v35-stereo/#findComment-7285549
I replaced my stock 2003 Bose stereo with a Pioneer double din screen. I didn't have any adapters and I retained the amp and both back speakers. I can honestly say after owning and doing up car stereos that my car sounds like it has a sub. It is insane! Don't know what i did to retain the amp.
https://www.sau.com.au/forums/topic/393494-v35-stereo/#findComment-7288020
    • As strange as this sounds (as they are fixed back), my Bride Xero CS seats are the most comfortable seats I've used.  I vote go genuine.  The only downside I've found is on very long drives, you can't reposition your body while driving. So even though its comfy, being locked in the same position eventually becomes uncomfortable. I find myself stopping every 3 or so hours to stretch my legs on long drives.
    • You don't have to be bored driving a Camry. Not based on the way that a couple of f**king Ubereats/Didi/othersortofmethaddlednightshiftattheservicestationrecentimmmigrants were piloting them on the way to work this morning. f**k me dead!
    • FWIW, the Bride reps are really nice to sit in. The only complaint I have, other than the tear in my bolster, is that the velcro used to hold the backrest cushion in place, up under the headrest, is a little obvious and intrusive and could probably be done better. I don't know if that is a "feature" on the genuine ones also though. I haven't looked at a genuine one like the ones I have, only some of the older models. The other thing is, even though I bought the CF ones, I think the CF is really just decorative, over the top of the same FG as the normal seats. And so they really aren't light. Between the solidly built CF/FG seat, the steel frame in the recliner mechanism, and the solid-arse seat rail, they are probably heavier than even the stock seat. They are a serious lift to get in and out of the car.
    • Yes, and so the barest minimum power target is the one that makes the most sense. Massive power is fun, but you can only use it for 1.5s at a time, and only every now and then. Medium power levels allow you to enjoy the car far more often and for longer. 500 engine HP is just below 300 rwkW which is about the maximum that is sensible for any street car really. And for a 2.6L six, it will still leave you with a decent boost response and some sort of linearity of power delivery. As you get up towards 400rwkW the onset of power tends to be increasingly like a cliff and you need drag radials to keep the ground in proper contact with the car, and.... it's just not a car for driving around any more.
    • I already reached that conclusion myself after reading up a whole bunch and watching various videos from multiple sources. Don't know yet how I'd best manage that with the least amount of headache. Probably pulling the sump and just welding on a AN10 adapter or something. I also think it's healthy to take most opinions with a grain of salt, because experiences differ wildly and especially Aussies - when talking about RBs - don't know a world below 600whp drag builds. Personally I doubt I will ever take my R33 racing, so it's going to be a street car with the occasional spirited drive. Hence why I am (so far) under the impression that I'm going to be fine with a stock-ish engine for a while.
