So dunno if you guys haven't heard about this and aren't excited, or have heard about it an assumed everyone had also... But there is a new PC coming out from the UK. It's the size of a credit card and was primarily devoloped to be supplied to schools to encourage kids to learn to program. You plug in your mouse, KB, SD card with apps/OS, power (micro-USB), a monitor (HDMI) and you're off. There are some pretty cool possibilities with the Raspberry Pi; From real Pip Boys, to a new range of Carputers, to home media centres (can play full 1080p), to kids actually learning how to program. The Raspberry Pi speaks Python and is going for real low cheap. How Cheap? $25-$35 (there are 2 models thus far - 128 and 256mb). Unfortunately they are sold out at the moment, and their website crashed 2 days ago on launch from the demand. But the world will eventually get a slice of the Pi. May even give me a chance to learn how to use Python...
Check it out!
Their Website
Raspberry Pi Wiki
DISCUSS!:geek:
https://www.sau.com.au/forums/topic/393516-raspberry-pi/
not sure ill put money down today since its only $35 US get a 32gb sd card and there is heaps of songs and stuff for carputer
all we need is a nice plastic case maybe Jaycar or someone in the know would know where to get them made
https://www.sau.com.au/forums/topic/393516-raspberry-pi/#findComment-6259312
  • 3 weeks later...
did you end up gettign this Madaz?
was thinking of getting it to run in the car as well!
They still havent got emissions certification so no customers have them yet. You might want to wait till the second batch come out though as they will be cased and may have more options (more RAM, I/O etc).
https://www.sau.com.au/forums/topic/393516-raspberry-pi/#findComment-6301858
any release dates on the second batch ?
I haven't seen any but even if there were some dates available I wouldn't have much faith in them being adhered to. I don't think they have even decided on a design yet. There are plenty of people making their own cases so it might be worth considering. A mate had a mini ITX computer set up inside a remote control car body (Skyline of course). With the smaller footprint of the Raspberry you could do it with a plastic airfix model, or a tupperware box or anything.
Someone designed this Lego case - check here for some other ideas people have had http://www.raspberrypi.org/forum/general-discussion/cases-for-the-raspberry-pi
Edited by *LOACH*
https://www.sau.com.au/forums/topic/393516-raspberry-pi/#findComment-6304251
Just an update - the PIs are now being received by customers.
There is quite a backlog so if one is ordered today it won't be received until about July.
I think the case design is finalised but you can't actually order it yet.
https://www.sau.com.au/forums/topic/393516-raspberry-pi/#findComment-6322122
    • Yeah the issue here is that we have a lot of topics, unless we matched on the exact word & phrase we'd get a million topics and the one you want will not likely be in the top 20 or so.
    • Yeah great idea, I have already added R32 Wiring Diagram but we can add as many as we want. 100% ! This has been something I've wanted to do for a while. I thought we could have a way for people to 'suggest' a link be added to the library when they come across something good.  We could kick this along by allowing members (maybe a subset) to tag threads they find to allow us to more easily find/locate/use good content, ie a tag 'for-library' which can then be added to the library and maybe have the tags reviewed and updated to better match the content. This would make it easier then to find the content when not using the library. We can also create pages that have lists of content with specific tags. That would allow us to add a tag and then have it automatically added to a page. We could have a page just for the 'for-library' content that we could then moderate and put wherever.  This excites me, the lack of structure with the amount of content is a little overwhelming.
    • Of course you can. That was a waste. Straight down one oil drain gallery and out the sump hole. Could at least have run the engine a little (obviously with at least minimum oil level on the stick).
    • Oh really? Maybe I'm being silly. I'll get some more shots. I had it higher but found that it went too high after a drive, I never knew this but exhausts can move around a bit when hot (makes sense, just never knew) and when it was higher it would make nice cooking plastic smells. That said, I could put some heat tape on a'la 90's R33 exhausts     Ha, I've spent a lot of my life in castle hill waiting for cars to be done. I think I'd prefer something closer but thanks D.
    • @Duncan Yes, changed filter every time. I don't have the service manual for the car yet (Car was imported and they removed everything when importing). I've been using the oil change threads in the forum as reference.   @Milkmun The second oil change was after ~4 months after the first months and I wasn't sure about reusing engine oil that was opened. The third oil change happened within 3 weeks of the second oil change and I used the previous leftover oil to just "clean up" the system. (Poured it through while the sump plug was open")
