So dunno if you guys haven't heard about this and aren't excited, or have heard about it an assumed everyone had also... But there is a new PC coming out from the UK. It's the size of a credit card and was primarily devoloped to be supplied to schools to encourage kids to learn to program. You plug in your mouse, KB, SD card with apps/OS, power (micro-USB), a monitor (HDMI) and you're off. There are some pretty cool possibilities with the Raspberry Pi; From real Pip Boys, to a new range of Carputers, to home media centres (can play full 1080p), to kids actually learning how to program. The Raspberry Pi speaks Python and is going for real low cheap. How Cheap? $25-$35 (there are 2 models thus far - 128 and 256mb). Unfortunately they are sold out at the moment, and their website crashed 2 days ago on launch from the demand. But the world will eventually get a slice of the Pi. May even give me a chance to learn how to use Python...
Check it out!
Their Website
Raspberry Pi Wiki
DISCUSS!:geek:
https://www.sau.com.au/forums/topic/393516-raspberry-pi/
not sure ill put money down today since its only $35 US get a 32gb sd card and there is heaps of songs and stuff for carputer
all we need is a nice plastic case maybe Jaycar or someone in the know would know where to get them made
https://www.sau.com.au/forums/topic/393516-raspberry-pi/#findComment-6259312
  • 3 weeks later...
did you end up gettign this Madaz?
was thinking of getting it to run in the car as well!
They still havent got emissions certification so no customers have them yet. You might want to wait till the second batch come out though as they will be cased and may have more options (more RAM, I/O etc).
https://www.sau.com.au/forums/topic/393516-raspberry-pi/#findComment-6301858
any release dates on the second batch ?
I haven't seen any but even if there were some dates available I wouldn't have much faith in them being adhered to. I don't think they have even decided on a design yet. There are plenty of people making their own cases so it might be worth considering. A mate had a mini ITX computer set up inside a remote control car body (Skyline of course). With the smaller footprint of the Raspberry you could do it with a plastic airfix model, or a tupperware box or anything.
Someone designed this Lego case - check here for some other ideas people have had http://www.raspberrypi.org/forum/general-discussion/cases-for-the-raspberry-pi
Edited by *LOACH*
https://www.sau.com.au/forums/topic/393516-raspberry-pi/#findComment-6304251
Just an update - the PIs are now being received by customers.
There is quite a backlog so if one is ordered today it won't be received until about July.
I think the case design is finalised but you can't actually order it yet.
https://www.sau.com.au/forums/topic/393516-raspberry-pi/#findComment-6322122
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
