Since returning from overseas I am now placing all parts up for sale from my R32 GTR.
Please note: more photos to come on Monday/Tuesday.
1. RB26 VIRGIN ENGINE BLOCK (bare block in good condition) $800
2. R33 GTR RB26 Crankshaft (purchased brand new and used for approx 15,000 km's) $350
3. RB26 RACEPACE FORGED PISTONS 86.5mm (used for 20,000 km's) $400
(slight damage to 1 piston as per photo - engine builder assures that it can be reused or another one can be sourced from racepace)
4. RB26 ADJUSTABLE CAM GEARS (good condition unsure of brand) $200
5. RB26 COMPLETE HEAD (head fully rebuilt less than 20,000 km's ago. Head has been pulled down
and needs to be re-assembled all parts included) $500
6. RB26 STOCK INTAKE PLENUM, THROTTLE BODDIES & THIRD SECTION $450
7. RB26 POLISHED ENGINE COVERS ALL 4 PIECES SOLD
8. SPLITFIRE COIL PACKS (less than 20,000 km's - good condition) $400
9. 700CC DENSO INJECTORS (pushed 400kw without any issues) $450
See photo in item 6.
10. GARRET -5 TURBOS (very good conditions done less than 20,000 km's) $2100
11. DUMP PIPES - XFORCE WITH 02 SENSORS (good condition) $250
see photo - item 10
12. POWER FC WITH HAND CONTROLLER (good condition a few pixels burn out on hand controller
screen) $700
Pictures to come.
13. OIL FILTER RELOCATION KIT & CUSTOM RACEPACE OIL COOLER WITH METAL DUCTING $500
Pictures to come.
14. RACEPACE CUSTOM CATCH CAN ALLOY $200
Pictures to come
15. RB26 R33 GEARBOX (working fine when in car) $500
Pictures to come.
16. EXEDY TWIN PLATE CLUTCH PUSH TYPE (working fine in car 70% meat left. RRP $2,350) $800
17. R32 GTR SUMP & DIFF $300
18. Z32 AIR FLOW METERS (perfect condition) $350
Pictures to come.
19. ARC FRONT MOUNT INTERCOOLER $600
Pictures to come
20. JJR 40MM ALLOY RADIATOR $150
Pictures to come
21. R32 GTR STANDARD AFM'S $150
22. GREDDY RADIATOR NECK $50
Pictures to come
23. ALCON FRONT BRAKES (complete)
Pictures and details to come
24. CUSTOM 3.5 INCH EXHAUST (front pipe to tip) $500
25. CUSCO STRUT BRACE $200
Pictures to come
26. 18x9.5 BBS LM's $3500 (sold pending payment)
27. CUSTOM 3 POD HOLDER WITH DEFI BOOST, WATER & OIL TEMP GAUGES - DEFI CONTROLLER $500
Pictures to come
28. ARC BLUE OIL CAP $80
29. RB26 STARTER MOTORS X 2 $100 EACH
30. CUSCO AIR DIVERSION PLATE $100
Pictures to come
31. R32 GTR RADIATOR SHROUD $70
Pictures to come
32. R32 GTR AIRBOX $400
Pictures to come
33. R32 GTR QUARTER WINDOW GLASS (BOTH SIDES) $250
34. R32 GTR STEERING WHEEL (poor condition) $70
35. R32 GTR STOCK COMPUTER $250
36. R32 GTR N1 OIL PUMP (good condition) $120
37. R32 GTR POLISHED TURBO CROSSOVER PIPES $200
38. CATCH CAN (A) WITH LINES $200
39. CATCH CAN (B) $150
40. CATCH CAN © $120
41. PISTONS & RODS - RB26? RB30? $50
42. TURBO ELBOWS (A) $100
43. TURBO ELBOWS (B) $100
44. RB26 TIMING BELT COVER (2 of) $50 each
45. RB26 INTERNAL COVER $50
46. RB26 CAS $50
47. R32 GTR STOCK RADIATOR $50
48. R32 GTR ENGINE FAN $50
49. R32 GTR ENGINE MOUNTS $50
50. R32 GTR SANDWICH PLATE $50
51. R32 GTR ALTERNATOR $100
52. R32 GTR ENGINE BRACKETS $50
53. R32 GTR BALLANCER & PULLEYS $50
54. R32 GTR ASSORTED OIL LINES AND BITS $100
55. R32 GTR WATER PUMP $30
56. R32 GTR CLUSTER $100
57. NORGREN PRESSURE REG $100
58. R32 GTR 4WD COMPUTERS/SENSORS $500
59. R32 GTR CLIMATE CONTROL $50
60. R32 GTR KNOBS $50
61. R32 R33 SHORT SHIFTER NEW $180
62. R32 GTR UNDER PLENUM PARTS $50
63. R32 GTR CROSS OVER PIPE $100
64. R32 GTR MIRROS (3 of - 1 with glass) $50 each
MORE PARTS TO COME
CONTACT SAM 0439 702 702
LOCATED IN MELB
Edited by laspy
https://www.sau.com.au/forums/topic/393554-r32-gtr-rb26-parts-part-out/
Ill take these...
Pictures to come.
Pictures to come
Pictures to come
PM Sent
Edited by krayzie32
6. RB26 STOCK INTAKE PLENUM, THROTTLE BODDIES & THIRD SECTION $450 SOLD
10. GARRET -5 TURBOS (very good conditions done less than 20,000 km's) $2100 SOLD
11. DUMP PIPES - XFORCE WITH 02 SENSORS (good condition) $250 SOLD
see photo - item 10
screen) $700
Pictures to come.
Pictures to come.
Pictures to come
Pictures to come.
Pictures to come.
Pictures to come
Pictures to come
Pictures to come
Pictures to come
Pictures to come
Pictures to come
Pictures to come
Pictures to come
46. RB26 CAS $50
50. R32 GTR SANDWICH PLATE $50 SOLD
52. R32 GTR ENGINE BRACKETS $50 SOLD
54. R32 GTR ASSORTED OIL LINES AND BITS $100 SOLD
62. R32 GTR UNDER PLENUM PARTS $50 SOLD
MORE PARTS TO COME
LOCATED IN MELB
9. 700CC DENSO INJECTORS (pushed 400kw without any issues) $450 SOLD
see photo - item 10
screen) $700
Pictures to come.
- Speedflow fittings all around, 19 row Setrab unit, 300 PSI rated flame resistant hose made is USA, high quality alloy mounts
- Include release valve
Photo in bay
Pictures to come.
22. GREDDY RADIATOR NECK $50 SOLD
Pictures to come
23. ALCON FRONT BRAKES (complete) $4,300
- Alcon 6 piston 365mm fronts. Braided brake lines.
31. R32 GTR RADIATOR SHROUD (broken corner) $70
46. RB26 CAS $50
49. R32 GTR ENGINE MOUNTS $50 (Sold - pending payment)
65. ALLOY BATTERY CLAMP SUIT SMALL BATTERY ROATED SIDE ON. $80
MORE PARTS TO COME
LOCATED IN MELB
UPDATE
and needs to be re-assembled all parts included) $500 (sold pending payment)
screen) $700
13. OIL FILTER RELOCATION KIT & CUSTOM RACEPACE OIL COOLER WITH METAL DUCTING $500 (Sold pending payment)
14. RACEPACE CUSTOM CATCH CAN ALLOY $200 (Sold pending payment)
26. 18x9.5 BBS LM's $3500 (Sold pending payment)
44. RB26 TIMING BELT COVER (2 of) $50 each (1 sold pending payment)
45. RB26 INTERNAL COVER $50 (sold penfing payment)
46. RB26 CAS $50 (sold pending payment)
49. R32 GTR ENGINE MOUNTS $50 SOLD
63. R32 GTR CROSS OVER PIPE $100 SOLD
65. ALLOY BATTERY CLAMP SUIT SMALL BATTERY ROATED SIDE ON. $80 (sold pending payment)
MORE PARTS TO COME
LOCATED IN MELB
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
