hi guys.i got a r33 fitted with the rb20e motor.what i want to know howstrong are the diff and sideshafts fitted to this model.are they as strong as the turbo skylines' diffs and sideshafts.how do i know if its a r200 diff.my vin plate says rc4.00 does that mean its a r200 diff.if i want to fit a turbo diff do i need the whole casing or jus the intenals.hope anyone can help
https://www.sau.com.au/forums/topic/393575-r33-diff-and-driveshaft-strength/
Don't know about a RB20DE R33, but i'm fairly sure the 25DE and DET diffs/driveshafts are the same?
Few people having trouble with gearboxes on 25DE+T's or high powered RB20DET's, but rarely hear of blown diffs or drive shafts unless it's in BIG power applications.....
Any R200 diff is as strong as any other in the basic aspects (CW&P, centre casting, output halfshafts). In the case of the 2L R33, it's unlikely that the std diff is LSD. And even if it was, VLSDs are pus anyway. Don't look at putting any other centre into your existing housing. Just buy a secondhand mechanical diff already in a housing when you can get one from someone.
I got an R32GTR rear end in my Stagea both for the mechanical LSD and because the 6 x 1 half shafts are thicker than the R33 ones (other advantages are aluminium carriers and twin pot brakes although you will have to change the shocks).
my diff does that.i even done the one wheel up test and itd very hard to turn but when one wheel is on a loose surface like sand and the other on hard surface the one on sand would spin with a light touch on the gas pedal.is that normal for a vlsd
oops sorry man.my diff acts like a lsd.i've jacked up my car n both wheels turn in the same direction.same said to jack up one wheel n if it hard to turn then its a lsd.i've done that test too n its hard to turn the wheel.do viscous lsd work when the wheels turn slow cause when one wheel is on a hard surface n the other on sand the one on sand starts to spin n no power goes to the other wheel
<br />My diff is a piece of shit, limited slip my f**ken ass.<br />
<br /><br /><br />
I've just been driving mine for the first time since putting the helical centre in it. As far as I'm concerned, the VLSD that was in it before was effectively open. I now have to learn to drive the car again, because everything it does is different!
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
