Travis, you're completely missing the point. The Autosport ones ONLY suit calipers that came on cars with 296mm rotors. The cheaper ones from eBay are designed to suit calipers from cars with 280mm rotors. If you look carefully at the two different adaptors you will see that they are completely different design. The cheaper ones just push the 280mm legged caliper out to the 324mm rotor position. It does that radially. The Autosport one pushes the 296mm legged caliper out to the 324mm rotor position also, but because there's not enough room to do this purely radially, the adaptor also has to move the caliper around circumfrentially a little to provide room for both sets of fasteners. THIS is the giveaway that tells you you're not looking at the same thing. If you apply the 280-324 adaptor to the 296mm caliper, it will push it out even further than the 324mm position. About 340mm in fact. It is important to remember that the Z32 uses the same sized caliper as the R32, not the R33.
^^This guy knows.
I've actually got a few different types drawn up, if there is enough interest I can go talk to a laser cutter :thumbsup:
  • Replies 56
^^This guy knows.
showing interest for r33 gts-t to suit 350z rotors as they're much cheaper and can be easily sourced from the US compared to R34 GTR 324mm rotors
rough idea on approx cost??
^^This guy knows.
Laser cutter?
Many of the cheaper R33 kits are 3 piece brackets and that in my eyes is pretty nasty compared to the one piece UAS ones
Like I mentioned earlier, if you laser cut the main plate, then what are effecively thick ass washers to match the thickness of your hub then those setups often cause vibrations in the pedal as tolerances are far easier to get wrong. Well thats been my experience at least with some R33s I have driven with that setup.
Its just a note of caution as people have been able to get the setup to work fine.....but is another reason why I like the UAS one piece machined ones
No idea, hence why I said if there was enough interest I will go out of my way to find out :)
Is 350Z brembo the same offset as skyline? I know the stock 350z discs we use on the Stageas are a different offset to the skyline discs.
Laser cutter?
The ones I have been running (for several years) have the spacers welded to the brackets, have seen the loose spacer types which would be easier to make (no welding) and easier to change offsets according to what disc you want to run.
I made my own 10 years ago out of some 8mm steel plate and welded on lugs before you could buy adapters. Scabbed the steel so they cost $0. Weight wasn't issue due to the small amount used. Only took half hour to make after a few hours making a mdf template. Also had less pad overhang than bought adapters you get today. GTST to GTR rotors. Recommend giving it a go! Mine survived many track and few drift days without ever loosening.
hey guys,
just spoke with GK-TECH (sponsor on here) as he just finished a set for Z32/R32/S14/S15 brakes to run 324mm rotors, and i've asked him to speak with his engineer to see if he can make a set to suit R33 GTST calipers with either 324 or 330mm rotors.
Will report back with (hopefully) good news. :thumbsup:
hey guys,
It would be interesting to see whether they can do something for a lower price than the UAS version; I'd definitely be interested :thumbsup:
dori34 the 350z brembo type rotors you mentioned above, are they the same hat offset as 324mm gtr rotors?
The 350Z brembo and GTR Brembo use a different hat offset. From memory, the GTR Brembo is 54mm and the 350Z Brembo is 49mm.
350Z Brembo Rotors are almost always significantly cheaper than the GTR version.
how does the hat offset make a difference when fitting? (noob Q here)
Well GK-TECH is selling the Z32/R32/S14/S15 adapters for $99.
and he did mention about one store selling the R33 GTST adapters for $350 is a bit rich and his cost will be well below this.
so take that as a hint it will be decently priced like all his gear :thumbsup:
$99 is a good price, but that particular adapter is fairly straightforward. It's literally a rectangular block with a step, two threaded holes, and two through holes :thumbsup:
The hat offset is the distance from the wheel mounting face of the disc rotor; to the front braking surface of the rotor.
This dimension dictates where the Caliper needs to sit in relation to the hub face; and therefore the thickness of the mounting spacer.
Edited by Daleo
:yes:
I was going to swap my 324mm package over to my 34 but I managed to get a GT-V so it already has the 310mm brakes, seems like a lot of effort for only 14mm increase in OD.
Anyone know of an 337-340mm rotor with a similar offset?
There are loads of options if you want 2pce. If you want single piece then a little more limited. About the cheapest I could find was a modified Mercedes ML rotor that was 340-343mm, but needed some machining to suit a Nissan. All up it was only going to be about $450 pair.
That is the only generic option you have. If you want to go 355mm then there are loads of opptions but the suitability of the Sumitomo caliper is questionable
:yes:
330mm nissan rotor
334mm toyota/lexus rotor
334mm vw golf R32 two-piece rotor (offset is very little though)
340mm audi tt-s rotor
345mm merc rotor
345mm audi rotor (3 different offsets)
make up your mind :)
Agreed, fitment under my rims would probably be an issue at that size too.
330mm nissan rotor
345mm merc rotor
Cheers :)
There is a bloke db power I think it is that sells an adaptor and rotor kit, bout 700 delivered to Aus. Mild steel adaptors and 345mm brembo rotors. Does one for 33 gtst, 32 and one for S15 etc.
Yep, he uses OE replacement rotors off W163 Merc ML, so if you find rotors locally, you can save money on delivery and order brackets only. Rotors will have to be modified - mounting redrilled to 5x114.3 and hub hole extended to 68mm.
  • 1 month later...
  • 2 months later...
