  • Replies 45
http://www.otomoto.com.au/c/4073478/1/used-wheels.html
Ben also brings in used JDM wheels, the warehouse has some amazing goodies...
I have bought old rims, then got them sand blasted, then powdercoated, all up its about $60 per rim. Looks great too.
He looks good value!!! having said that the wheels are few and far between (offset/size wize) but you never know!
Dan, im going to put 10+kg fronts in mine its about the same as a track s13 would run and withthis new setup i intend to do track days in it,
i didnt get to speak to the flairs guys today but i will do, id say z flairs would fit.
Cheers
arghhhhh!!!!!! what are you doing to me haha they are sick!! but there to big i think?? also i really would love more dish 10-10.5, 11??
im really feeling 16s to be honest but maybe your right??? i really want to nail that image top of this thread though i think 16s look like the go to me.
rotas would save alot of money! (lets not make this into a debate about there quality please!!!) in particular if the fitment is not right it does not cost me 2500!!
also i made these tonight
Koni adjustable's with 8kg springs
on to the front next im using the the originals and putting in koni Z31 inserts which makes them 45mm ish shorter
Edited by FJ20DR30
Dude only 15 Watanabes if you want a legit look like the model.
Offset calculator-
http://www.1010tires.com/wheeloffsetcalculator.asp
If that fails, Ben from Otomoto Has owned a DR in the past and currently owns another. If he doesn't know approx specs you would need he may be able to ask someone.
Also keen to see how you navigate cutting the guards as I need to do mine too (harder for me as flairs are already attached).
Edited by D-limo
I have emailed Ben, no response as yet..
I have also been attempting to overlay images over the image of that toy and they really seem bigger than 15"(hence why I'm thinking 16 ATM, if you look at the wheel space at the front in particular and compare that to a car with 15s the wheel on the toy fills it better with a smaller profile tire don't you think?
As for guard cutting! That still gives me nightmares haha, I'll likely get the panel shop next door do it..
  • 4 months later...
    • Driveability will be about the same with either externally venting BOV, or no BOV at all. Perhaps worse one way than the other, with me thinking that the definitely more flow going through the AFM through a venting BOV more likely to cause rich stalls than the perhaps more flow that the AFM might read on reversion. There is no such thing as "turbo damage" from not having a BOV at stock, or even quite a lot higher than stock, power levels. You need a big turbo with a lot of mass spinning hard getting a horrible slowdown from a slammed shut throttle before there is anything like the shaft loads required to damage things. Not an issue on small turbos. The ONLY 2 reasons that Nissan put a recirc valve onto the RB were: It is a bypass valve. It is open when under vacuum. When not on boost, it bypasses intake air forward around the compressor, which unloads the compressor, allowing the turbine to sping more freely, making the whole lot a bit more efficient when just puddling around. Throttle response should also be faster via the shorter, smaller diameter BOV pipe (when in NA, ie before the BOV closes and boost is building) which is nicer for driveability. Emissions. The reversion causes CO pulses. Eliminate the reversion (or at least, keep it away from the AFM) and you don't get that. The stalling/driveability aspect could have been tuned around, as shown one example of by dose above, if Nissan hadn't put a recirc valve on. Many many turbo engines before the RB had no BOV. They did not stall. See the RB30 turbo as an example. Nistune is definitely better than just stock ECU. It allows you to access and change things that are not excellent on the stock setup, and allows you to do mods like put decent injectors in, relocate the AFM, put a bigger turbo or even cams, etc, on, change to coil swith completely different swell needs, etc etc. All the things that you might need or want to do 25 years after the car was new. Aftermarket replacement ECU is obviously better again, because it gives you even more freedom from the constraints of the stock ECU. I won't be needing to go any further than Nistune though, for the new turbo in the 250ish rwkW region I'm going to, with big injectors, and most other things being stockish.
    • Lucky the prp block is supposed to be released next weekend
    • Wow guys thank you very much for the HUGE info :-) @GTSBoy I have like 30 minutes if test drive with that car/engine and it not stalled once. IMO it ran very smooth so i guess it was not that bad(but asi i said it is stock) That atmo BoV is worse than no BoV or in my case or it is/will be the same? Cuz frankly i rather have little whooosh sound than that sututu 馃槃 But either way the less harmfull for engine/turbo the better(if the stock is not an option right away) Yeah about that rebuild i talk with guy who will be doing swap and custom pipes...i think i can get stock BoV or get aftermarket which will function the same. Yeah i looked at that R35 option and i try ask my mechanic more about that if he knows. The engine has stock ECU but i can get Nistune for it. On that stock it runs quite well...but i have limited time with it so rly dont know. Ecumaster is this https://www.ecumaster.com/  It is not some dodgy backyard ECU :-)  @MBS206 Yeah but it will be better to have Nistune than the completely stock ECU no? About that "same" atmo/no BoV. The drivebility would be the same? I dont know but i kinda guess that amto BoV would cause more problems than no BoV in my case? Or is the same? You just "change" one sound for the other? Yeah i read many many many topic about hurting the turbo. But no one know anybody that would 100% tell that his turbo/engine blows/get damaged by not running BoV. Of course turbo would be little happier IMO if it has BoV ..but if you do not trash i think i should be good. And as you can see iam already trying to get this right...just working what i have right now :-) Yeah iam kinda the same...i dont want nothing loud and frankly iam not liking that sututu noise that much 馃槃 i rather have little bit of "whooosh" or no sound at all. Of course in my case it si a completely another world when you came tu Turbo car with open air box and no BoV and you driving the N/A ...all i hear is engine. Here? I heard turbo/sucking and that sututu 馃槃 @Yeetus So in my case it is really no difference to run no BoV or some atmo BoV like GReddy FV2? The car would drive the same and has "the same" little problems? As i wrote above i kinda thinked that atmo BoV with stock MAF would cause more problems...but then again i dont know much about no BoV either :-)  So to avoid stalling i "cant" just put neutral on stop lights like from higher rpm? Or? Yeah iam already looking for ECU :-)  Yes iam at the same side with thar R35 MAF :-)  @Dose Pipe Sutututu Thank you i (my mechanic/tuner) will look into that) Guess iam taking the Nistune at least :-)
    • Here's the workaround with Nistune I was talking about, just add in more timing on the decel table And play around with the fuel cut & recovery, it's enough to stop it from stalling on a decel
    • Hi Apex and welcome!
